Cordless Drill/Drivers
Our tester compares 10 cordless drill/drivers for speed, power, and performance.
14 MIN READ
15.6 Volts
Specs are provided by each manufacturer and are not verified by Tools of the Trade.
Hilti Weight Battery Type Volts Rpm (Low/High) # of Batteries as Standard Equipment
SF 150-A 14 lbs. NiMH 15.6 0-450 / 0-1,450 2
No Image Available
StoryID
501167
ToolNumber
1
ComponentId
tcm:78-1626727
Tester Comments
Despite its long, vertical battery, this drill has nice balance. The ratcheting/locking chuck grabbed and released bits well, but the tool could use more power. The battery release was awkward. I felt like my fingers didn’t have good contact with the contoured reverse switch. This tool also could use a better storage box.
Price
$99
Contact
800-879-8000
www.us.hilti.com
Panasonic Weight Battery Type Volts Rpm (Low/High) # of Batteries as Standard Equipment
EY6432GQKW 4.8 lbs. NiMH 15.6 65-450 / 200-1,450 2
No Image Available
StoryID
501167
ToolNumber
2
ComponentId
tcm:78-1626727
Tester Comments
This is the lightest and most compact tool in the bunch. It’s good in tight spaces and fits well in smaller hands. The plastic ratcheting/locking chuck has a metal nose, and the chuck grabs and releases bits nicely. The battery exchange works well, too. This tool drilled a large number of holes considering its small size, but heated up during the spade-bit test.
Price
$220
Contact
800-338-0552
www.panasonic.com/cordlesstools
18 Volts
Bosch Weight Battery Type Volts Rpm (Low/High) # of Batteries as Standard Equipment
33618 5.7 lbs. Nicad 18 0-400 / 0-1,300 2
No Image Available
StoryID
501167
ToolNumber
3
ComponentId
tcm:78-1626727
Tester Comments
This tool is terrific. Its plastic-and-metal ratcheting/locking chuck works nicely. It has excellent balance, a non-slip handle, and good battery exchange. The compact tool drilled 79 1-inch holes on a single charge and has the best low-end torque. The reverse switch is hollow and the high-speed rpms are a little too slow. It comes with battery end caps and a good box. The battery stem sits high in the charger and looks breakable.
Price
$240
Contact
877-267-2499
www.boschtools.com
Craftsman Weight Battery Type Volts Rpm (Low/High) # of Batteries as Standard Equipment
27124 6.88 lbs. Nicad 18 0-400 / 0-1,400 2
No Image Available
StoryID
501167
ToolNumber
4
ComponentId
tcm:78-1626727
Tester Comments
The plastic and metal chuck on this tool worked really well and I thought the bubble level built into the tool body could come in handy. The tool is oversized, however, and the extra-long handle makes it uncomfortable to use. It drilled only an average number of holes. The easy-on front-slide battery is a good feature.
Price
$200
Contact
800-377-7414
www.sears.com/craftsman
DeWalt Weight Battery Type Volts Rpm (Low/High) # of Batteries as Standard Equipment
DW987K-2 5.9 lbs. Nicad 18 0-450 / 0-1,450 / 0-2,000 2
No Image Available
StoryID
501167
ToolNumber
5
ComponentId
tcm:78-1626727
Tester Comments
At 2,000 rpms this tool is a speed demon. Its ratcheting/locking chuck is plastic with a metal nose and works great. The tool is very compact with nice balance and a good power-to-weight ratio. It has an easy battery exchange and a comfortable anti-slip handle. The three speed settings allow you to adjust your combination of torque and speed based on application. Like a lot of these tools, this one could use a better storage box.
Price
$270
Contact
800-433-9258
www.dewalt.com
Hitachi Weight Battery Type Volts Rpm (Low/High) # of Batteries as Standard Equipment
DS18DVB 5.3 lbs. Nicad 18 0-400 / 0-1,400 2
No Image Available
StoryID
501167
ToolNumber
6
ComponentId
tcm:78-1626727
Tester Comments
This is a very comfortable tool. It has an older-style plastic chuck with a metal nose that jammed during the spade-bit test. The entire handle is non-slip and easy-to-hold. Its battery exchange is easy. The slight angle between the motor and battery helps the balance, but the large vertical battery out at the end of the handle makes it feel ungainly. The tool seemed plenty tough, but could use more power.
Price
$210
Contact
800-829-4752
www.hitachi.com/hpt
Makita Weight Battery Type Volts Rpm (Low/High) # of Batteries as Standard Equipment
6347DWDE 5.3 lbs. NiMH 18 0-400 / 0-1,300 2
No Image Available
StoryID
501167
ToolNumber
7
ComponentId
tcm:78-1626727
Tester Comments
This tool has good power and speed. It has an older chuck design that jammed a little during the spade-bit test. I liked the anti-slip handle and easy battery exchange. The battery is spread wide from the motor, giving it great balance. Its drill-only switch needs to be improved though; the button you press to engage it is way too small. The box was big enough to carry a tool with the bit on, which I like.
Price
$239
Contact
800-462-5482
www.makitatools.com
Metabo Weight Battery Type Volts Rpm (Low/High) # of Batteries as Standard Equipment
BST18 Plus 5.3 lbs.. Nicad 18 0-450 / 0-1,650 2
No Image Available
StoryID
501167
ToolNumber
8
ComponentId
tcm:78-1626727
Tester Comments
This tool has the best battery release out there. It has a good chuck that ratchets and locks, but it’s mostly plastic. The drill also has good low-end torque, but could use more high-speed power. I found the balance and handle a bit awkward and thought the reverse button was difficult to press. It’s got a good, solid box that allows you to store the tool with a bit attached.
Price
$309
Contact
800-638-2264
www.metabousa.com
Milwaukee Weight Battery Type Volts Rpm (Low/High) # of Batteries as Standard Equipment
0622-24 Lok-Tor 5.8 lbs. Nicad 18 0-500 / 0-1,700 2
No Image Available
StoryID
501167
ToolNumber
9
ComponentId
tcm:78-1626727
Tester Comments
I loved everything about this drill. Its all-metal ratcheting/locking chuck is bulletproof. The narrow, non-slip handle is comfortable, the balance is great, and it has lots of power in a compact package. The slide-in battery exchange is easy. It drilled a massive number of high-speed holes (89) on a single charge. It has top-notch low-end torque, too. The box is solid and rugged with strong metal clasps and a good bit carry-all inside
Price
$227 – $318
Contact
800-414-6527
www.heavydutytool.com
Porter-Cable Weight Battery Type Volts Rpm (Low/High) # of Batteries as Standard Equipment
9984 6.2 lbs. Nicad 19.2 0-550 / 0-1,500 2
No Image Available
StoryID
501167
ToolNumber
10
ComponentId
tcm:78-1626727
Tester Comments
I loved this drill. The all-metal ratcheting/locking chuck is superb. This tool feels very balanced, and the larger battery didn’t make the tool feel bigger or heavier. The rear-slide battery takes some getting used to, though. I like the anti-slip handle. This model drilled tons of holes on both high and low speeds and has excellent power.
Price
$245
Contact
800-487-8665
www.porter-cable.com
19.2 Volts
Rex Cauldwell
Rex Cauldwell is a master electrician and owner of Little Mountain Plumbing and Electric in Copper Hill, Va.
