| Bosch | Weight | Amps | Horsepower | Collet Size | RPM | Soft Start |
| 1617EVSPK | Fixed Base: 7.5 lbs. / Plunge Base: 10 lbs. | 12. | 2-1/4 | 1/4-, 3/8-, 1/2-inch, 8-mm | 8,000 to 25,000 | Yes |
StoryID
501244
ToolNumber
1
ComponentId
tcm:78-1626785
Tester Comments This kit does the most things the best. Plunge action is smooth and the spring is just the right tension. All of the switches are easy to reach, especially in the plunge configuration, and it has a low center of gravity for a work-hugging feel. The bases and motor switch easily. It uses a two-wrench bit change; the 1/2-inch collet gave us some trouble, but the other collets work great. It ships with a great quick-change template adapter and has a good storage box. | Price $249 Contact 877-267-2499 www.boschtools.com | null | null | null | null |
| DeWalt | Weight | Amps | Horsepower | Collet Size | RPM | Soft Start |
| DW618PK | Fixed Base: 7.5 lbs. / Plunge Base: 10.1 lbs. | 12 | 2-1/4 | 1/4-, 1/2-inch | 8,000 to 24,000 | Yes |
StoryID
501244
ToolNumber
2
ComponentId
tcm:78-1626785
Tester Comments Swapping bases on this unit is slick and fast. A spindle lock enables a one-wrench bit change — the nicest of the bunch. The balance is great in both configurations. It also has the best dust collection design of the group. The kit comes with extra base plates and ships with a base-plate centering device for using large bits. The plunge-lock lever is difficult to lock securely, which affects cut-depth consistency. The carrying case is too big. We like the detachable cord. | Price $249 Contact 800-433-9258 www.dewalt.com | null | null | null | null |
| Makita | Weight | Amps | Horsepower | Collet Size | RPM | Soft Start |
| RF1101KIT | Fixed Base: 7.9 lbs. / Plunge Base: 9.3 lbs. | 11 | 2-1/4 | 1/4-, 1/2-inch | 8,000 to 24,000 | Yes |
StoryID
501244
ToolNumber
3
ComponentId
tcm:78-1626785
Tester Comments This tool’s base conversion is easy. The switches and levers are easy to find; it’s possible to accidentally activate the top-mounted power switch, though. The plunge-lock lever and the plunge action feel stiff, which makes the tool difficult to control in the cut. It has the best case of the bunch — well organized — and it’s the only tool that ships with an edge guide and a dust port. It also comes with an extra base for large bits. | Price $298 Contact 800-462-5482 www.makitatools.com | null | null | null | null |
| Porter-Cable | Weight | Amps | Horsepower | Collet Size | RPM | Soft Start |
| 693LRPK | Fixed Base: 8.2 lbs. / Plunge Base: 11.4 lbs. | 11. | 1-3/4 | 1/4-, 1/2-inch | 10,000 to 27,500 | No |
StoryID
501244
ToolNumber
4
ComponentId
tcm:78-1626785
Tester Comments Plenty of power here, but this tool could use some improvements. Changing bases is difficult. The power switch is hard to find. The plunge action is too rough and the plunge lever doesn’t lock very well. Also, there’s no fine adjustment in the plunge configuration. | Price $179 Contact 800-487-8665 www.porter-cable.com | null | null | null | null |
