Tool Test: 18-Volt Drill/Drivers
Look for a fast, powerful tool with added features like a battery gauge and a light that stays on after the switch is released
17 MIN READ
Bosch Compact Tough (DDS181-02)
StoryID
1858896
ToolNumber
1
ComponentId
tcm:78-1630437
Battery: 18 volts; 1.5 Ah
Battery gauge: Yes; on battery
Weight: 3.42 pounds
Lenght 7-1/4 inches
RPM 0–500; 0–1,700
LED headlight: On base; no delay
Belt hook: Included
Web price: $190
Includes: Two batteries; charger; blow-molded plastic case
Warranty: 1 year tool, battery, and charger;
1 year free service; 30-day satisfaction guarantee; register for free ProVantage plan (3 years tool,
2 years battery, 1 year charger)
Country of origin: Mexico
Comments:—
Pro: Very short front-to-back; responsive trigger; includes battery gauge; available as bare tool (DDS181B)
Con: Light has no delay function
Bosch Brute Tough (DDH181-01)
StoryID
1858896
ToolNumber
2
ComponentId
tcm:78-1630437
Battery: 18 volts; 3.0 Ah
Weight: 4.72 pounds
Lenght 9-3/8 inches
RPM 0–380; 0–1,600
Belt hook: Not available
Web price: $295
Includes: Two batteries; charger; side handle; blow-molded plastic case
Warranty: 1 year tool, battery, and charger; 1 year free service; 30-day satisfaction guarantee; register for free ProVantage plan (3 years tool,
Country of origin: Malaysia
Comments:—
Pro: Comfortable grip; responsive trigger; includes battery gauge; available as bare tool (DDH181B)
DeWalt 20V MAX (DCD780C2)
StoryID
1858896
ToolNumber
3
ComponentId
tcm:78-1630437
Battery gauge: No
Weight: 3.50 pounds
Lenght 7-11/16 inches
RPM 0–600; 0–2,000
LED headlight: Above trigger; 20-second delay
Belt hook: Included
Web price: $200
Includes: Two batteries; charger; plastic case
Warranty: 3 years tool, charger, and battery; 1 year free service tool and charger; 90-day satisfaction guarantee
Country of origin: China
Comments:—
Pro: Very compact; thin comfortable grip; high top speed; right-sized case just big enough for what it needs to hold
Con: Feels somewhat less powerful than other compact models; chuck partially blocks light and creates a blind spot
DeWalt 20V MAX (DCD980L2)
StoryID
1858896
ToolNumber
4
ComponentId
tcm:78-1630437
Battery gauge: No
Weight: 5.22 pounds
Lenght 9-3/8 inches
RPM 0–575; 0–1,350; 0–2,000
Belt hook: Sold separately
Web price: $280
Includes: Two batteries; charger; side handle; plastic case
Comments:—
Pro: Good power; three-speed gear box; noticeably higher max rpm than other models; thin comfortable grip, sturdy metal side handle
Con: Heavier than average; belt clip not included; trigger not very sensitive; chuck partially blocks light and creates a blind spot
Festool T 18+3
StoryID
1858896
ToolNumber
5
ComponentId
tcm:78-1630437
Battery gauge: Yes; on tool
Weight: 4.22 pounds
Lenght 8 inches
RPM 0–450; 0–1,500
LED headlight: Above trigger; 1.5-second delay
Belt hook: Two included; one on either side of battery
Web price: $625
Includes: Two batteries; charger; Centrotec chuck; right-angle chuck; eccentric chuck; Systainer case
Warranty: 3 years tool, battery, and charger; 30-day satisfaction guarantee
Country of origin: Germany
Comments:—
Pro: Good power; superior runtime; includes four chuck options: standard, right angle, offset, and Centrotec; brushless motor; very sensitive trigger; electronic clutch; drill/drive modes separate from clutch
Con: Expensive; clutch adjustment wheel is easily knocked off setting; dual-sided belt hook is nice idea but harder to use than others; only tool in the battery system
Hilti SFC 18-A
StoryID
1858896
ToolNumber
6
ComponentId
tcm:78-1630437
Battery: 21.6 volts; 1.6 Ah or 3.3 Ah
Weight: 3.94 pounds (1.6 Ah); 4.62 pounds (3.3 Ah)
Lenght 8 inches
RPM 0–600; 0–1,800
LED headlight: On base; 10-second delay
Web price: $270 (1.6 Ah); $450 (3.3 Ah)
Includes: Two batteries; charger; soft gate-mouth bag
Warranty: Lifetime tool, battery, and charger against defects; 2 years wear and tear on tool, battery, and charger; fleet-management program
Comments:—
Pro: Excellent runtime with either size battery; thin comfortable handle; feels more powerful than the average compact tool; large carry bag; available as bare tool
Con: Longer and heavier than other compact models; belt hook not included
Shown with 1.6-Ah battery
Hitachi DS18DSAL
StoryID
1858896
ToolNumber
7
ComponentId
tcm:78-1630437
Battery gauge: No
Weight: 3.44 pounds
RPM 0–350; 0–1,500
LED headlight: Above trigger; no delay
Belt hook: Included
Web price: $155
Includes: Two slide-mount batteries; charger; flashlight; plastic case
Warranty: Lifetime tool; 2 years battery; 1 year charger; 30-day satisfaction guarantee
Comments:—
Pro: Light and compact; thin comfortable grip; nice belt clip; includes flashlight
Con: Limited number of tools compatible with these slide-mount batteries; no battery gauge
Hitachi DS18DL
StoryID
1858896
ToolNumber
8
ComponentId
tcm:78-1630437
Battery gauge: No
Weight: 5.25 pounds
Lenght 9-3/16 inches
RPM 0–400; 0–1,600
LED headlight: On belt hook; manually operated
Belt hook: Included
Web price: $280
Includes: Two tower batteries; charger; side handle; plastic case
Comments:—
Pro: Good power; can be set to very low rpm for delicate work; includes belt hook; fan-cooled charger; available as bare tool (DS18DLP4)
Con: Tower-style battery makes for bulky grip; no battery gauge; funky belt clip of questionable durability contains manually activated light
Makita LXFD01CW
StoryID
1858896
ToolNumber
9
ComponentId
tcm:78-1630437
Battery gauge: No
Weight: 3.40 pounds
Lenght 7-1/2 inches
RPM 0–400; 0–1,500
LED headlight: Above trigger; 12-second delay
Belt hook: Included
Web price: $190
Warranty: 3 years tool; 1 year battery and charger; 30-day satisfaction guarantee
Comments:—
Pro: Very light and compact; excellent fan-cooled charger
Con: Feels less powerful than other compact models; no battery gauge
Makita LXFD01
StoryID
1858896
ToolNumber
10
ComponentId
tcm:78-1630437
Battery gauge: No
Weight: 3.90 pounds
Lenght 7-1/2 inches
RPM 0–400; 0–1,500
Belt hook: Included
Web price: $295
Comments:—
Pro: Same internal parts as LXFD01CW; reasonable power and runtime with included 3.0-Ah batteries; excellent fan-cooled charger; available as bare tool (LXFD01Z)
Con: No battery gauge
Greg DiBernardo
“Passionate” is the best word that can be used to describe Greg DiBernardo. His professional world revolves around constructing beautiful outdoor spaces for his clients using cutting edge materials and methods that will stand the test of time.Greg is a nationally recognized figure in the deck building industry. He’s a regular contributor to the industry’s trade publication, Professional Deck Builder magazine, writing feature articles that dictate the deck and outdoor industry’s best practices for design, construction and management. He’s also a Contributing Editor for Tools of the Trade magazine and a frequent author for The Journal of Light Construction and Fine Home Building.He has been a presenter and speaker for the National Association of Remodelers (NARI) and large building supply companies on advanced deck building and business topics.A deck and construction industry insider, Greg’s notoriety affords him close personal connections with major industry manufacturers assisting them with product development, design and testing of new and existing building materials. Greg has also made TV appearances on the The Today Show, DIY Network, Extreme Makeover: Home Edition, House Smarts, and the Food Network. He resides in Canton, GA with his wife and daughter.
