Tool Test – Contractor Table Saws
Need a table saw that can pull long shifts on the jobsite and double as a low-cost shop saw? Here are six tools powerful enough to do it all.
14 MIN READ
Publication Date: January/February 2002
Tool
Weight
Table Dimensions
Rpm
Hp
Max. Cutting Depth
Street Price
Craftsman
22849
245 lbs.
20″ x 27″ (44″ x 27″ with extensions)
3,400
1.5
90°: 3 3/8″
45°: 2 1/4″
$599
Comments: Craftsman has been selling this saw style longer than I’ve been alive. I have an early version in my basement. Compared to the other saws in the test, Craftsman’s fence has a lot of catching up to do. The drive mechanism is identical to Ridgid’s and Delta’s and the motor has good power. It’s not as well machined, though, and has more slop than its brothers. www.sears.com/craftsman
Tool
Weight
Table Dimensions
Rpm
Hp
Max. Cutting Depth
Street Price
Delta
36-431
300 lbs.
60″ x 27″
3,000
1.5
90°: 3 1/8″
45°: 2 1/8″
$899
Comments: This is a nice, well-made saw. With its long fence rails and extension table, it’s a very attractive shop tool. It comes with a great Biesemeyer fence and uses an arbor wrench for blade changes. I wish the motor had more power. The saw’s dust-collection device is okay for the jobsite, but should be enclosed for a shop. www.deltamachinery.com
Tool
Weight
Table Dimensions
Rpm
Hp
Max. Cutting Depth
Street Price
DeWalt
DW746X
254 lbs.
40 3/4″ x 27″
3,000
1.75
90°: 3 1/8″
45°: 2 1/8″
$899
Comments: This saw is more of a junior cabinet saw than a traditional contractor’s saw. The fence allows a level of adjustment sophistication not found in its competitors. It’s the only saw with a drive mechanism that can’t jump and it’s got the best dust-collection port. It’s among the highest priced in this group and has excellent options like a cast iron sliding table, but they’ll cost you. www.dewalt.com
Tool
Weight
Table Dimensions
Rpm
Hp
Max. Cutting Depth
Street Price
Jet
JWTS-10CW2-JF
300 lbs.
40″ x 27″
3,450
1.5
90°: 3 1/8″
45°: 2 1/8″
$699
Comments: This saw does everything well. Its suspended-motor drive mechanism, like Powermatic’s, has fewer adjustments than the Ridgid, Delta, and Craftsman saws, and seems to work well. The switch is a classic push button–tried and true. The fence stayed square throughout the test, yet it’s not as finely made as the Biesemeyer or DeWalt fences. This model has a built-in dust-collection insert. www.jettools.com
Tool
Weight
Table Dimensions
Rpm
Hp
Max. Cutting Depth
Street Price
Powermatic
64A
321 lbs.
40″ x 27″
3,450
1.5
90°: 3 1/4″
45°: 2 1/8″
$899
Comments: This one’s very much like the Jet saw–a solid tool. I like the Biesemeyer-style fence very much, even though this fence has a smaller front section and a shorter “tee” than Delta’s Biesemeyer fence. The drive mechanism worked well in the test. The switch is a solid, industrial push button. The built-in dust-collection chute is nice. This saw will probably work hard and wear well. www.powermatic.com
Tool
Weight
Table Dimensions
Rpm
Hp
Max. Cutting Depth
Street Price
Ridgid
TS2424LS
254 lbs.
44″ x 27″
3,100
1.75
90°: 3 3/8″
45°: 2 1/4″
$597
Comments: This is a well-built saw. It assembles and disassembles quickly and moves easily, and is the best saw to take to your jobsites. The rolling base is standard equipment, and works well. The fence is excellent. Tight machining tolerances give it a smooth performance under load and the 1.75 hp motor handles tough cuts. www.ridgidwoodworking.com
This article is reprinted courtesy of Tools of the Trade
