Custom residential design is a complex creative process
involving the homeowner, designer, and builder. It takes time
and it's unreasonable to expect every decision to be made
before construction begins. Change orders provide a way to
fine-tune the big decisions. For the clients, a change order
may be the last chance to get what they really want. For the
contractor, change orders mean increased revenues without a lot
of trouble. After all, the crew is already on site working. All
you have to do is write the changes up and manage them
properly.
In my company, which has separate sales, management, and
production teams, change order management has involved
establishing good procedures, then assuring that everyone
understands and follows these procedures. Other companies may
be smaller and less complex, but the same basic procedures are
just as necessary.
Defining Change Orders
What is a change order? Is it any deviation from written specs
and drawings or is it only additional work? Regardless of what
a company's policy is, there has to be a definition that the
whole team understands and agrees on. At my company, change
orders include all deviations from the original scope of work,
plus all clarifications of job specs. Apart from assuring that
clients pay for extra work, this comprehensive definition
protects the company from the conflicts that often arise from
undocumented verbal agreements. With so many decisions being
made during a job and so many chances for decisions to conflict
with one another in unanticipated ways, documentation is the
only way to manage this information and avoid being wrongly
blamed. Clearly defining what constitutes a change order is
essential to setting up a system that prevents you from doing
unpaid work.
One way to better understand how change orders affect a
contracting business is to track them as a percentage of sales.
Historically, they have represented 10% of the total sales
volume in my company. That percentage breaks down into the
categories in the chart in Figure 1.
Types of Change Orders with
Examples |
Additional Requests |
3 additional can
lights |
Addition of bay window to
kitchen remodel job |
Addition of sunroom
to whole-house renovation |
Deletions |
Strike skylight from
bedroom remodel job |
Credit French door
cost and leave open archway instead |
Cancel brick chimney
and use direct-vent furnace instead |
Clarifications |
Paint color |
Tile choice |
Change of door size
(unless significant cost difference) |
Outlet and switch
placements |
Unknown/Below-Code Hidden
Conditions |
Sink vent goes
through king stud, must be reworked |
Illegal spliced wire
found in wall, must be replaced |
Dry rot in wall
requires that wall be rebuilt |
Design Errors/Omissions |
Wire between two wall
outlets needs to be rerouted for new doorway
opening to be framed |
Less than 4/12 roof
pitch requires more expensive flat roof
skylight |
New electric
circuits in addition require main panel to be
upgraded |
Figure
1. Change orders may stem from a variety of causes.
Additional requests, deletions, and clarifications present no
problems for clients; hidden conditions and design errors are a
tougher sell.
From top to bottom, the list goes from the easy-to-handle
change orders to the hard-to-handle ones. Clarifications,
additional requests, and deletions are all decisions that the
client makes voluntarily. They are easy to agree on. Hidden
problems, such as unknown code violations or unknown
constraints, can be more difficult. Clients often resent local
building codes forcing them to perform extra work or
subcontractors insisting on higher than expected costs due to
some unforeseeable problem. Forewarning clients about these
potential situations lessens their shock when one actually
happens.
The final category, designer or architect errors and
omissions, is the most difficult category to handle. Good will
between a contractor and a customer can evaporate quickly.
Clients may feel betrayed and think that expensive extra work
should have been foreseen by the builder before work began.
Often, in order to preserve customer relations, companies have
to absorb the cost of problems that should have been foreseen.
Fortunately, a solid change order procedure helps to eliminate
these project planning problems in the future. The key is to
use past change orders to learn from mistakes and improve
future work.
The Original Contract
The
original contract for a job must clearly set out the scope and
cost of agreed upon work. It also has to clearly define what
change orders are and the procedure for how they are processed.
In addition to a change order clause in our standard job
contract (Figure 2), our project specifications include clear
language stating that work beyond the defined specifications
will only be performed after receiving a signed change
order.
We have read these Contract
Specifications and completely understand the contents.
Any changes or additions will be handled through a Change
Order.
Figure
2. This simple clause makes the change order process a
part of the original contract.
For example, specifications for a kitchen remodeling job
would include a clause stating: We will make every attempt
not to damage the drywall of an adjoining room. However, if
nail pops occur, we will write a change order for drywall
repair and paint.
To ensure that clients understand the change order process,
we also give them a one-page handout that describes change
orders. We read through this with the clients and have them
sign it before work begins (see ). While it may be easy for a
client to miss the change order clause in the original
comprehensive contract, they can't fail to at least look over
this explanatory page — after all, they have to sign
it.
Later, as a job develops, we introduce clients to the
process by writing up clarification change orders for items
such as paint colors or new locations for light switches. These
do not affect the budget but become part of the written history
of the job. Clarification change orders get the client used to
the process and quell the fear that change orders always mean
more money.
Writing the Change Orders
Changes need to be identified and described, then processed
into a formal change order signed by all parties before the
scope of work is changed. This ensures that clients and
subcontractors agree with you concerning any cost adjustments
and schedule delays caused by change order work, both of which
should be spelled out in the paperwork you use (Figure 3).
Figure
3. The completed change order specifies the type of
change, the scope and cost of the new work, and the additional
time added to the schedule.
Include in all change orders a clause stating that any
additional work must be done at the same time as the original
scope of work for the price to be valid.
At my company, our charges to clients for change orders
include administration time, material cost, work crew time and
subcontractor cost, and a full profit margin. To ensure that
clients will meet their end of the bargain, we require a 50%
deposit before change order work begins and the balance when it
is complete. On deletion change orders, only the actual labor
and material costs are deducted from the original contract
price. Markup and profit are not deducted because the company
has already spent time planning for the work and must recover
these overhead costs.
