My company has been building custom sun decks and porches in
northern Virginia for the past 17 years. In that time, we've
developed uniform production methods and selected premium
materials that enable us to sell more than 120 projects every
year.
Details and custom options not only sell decks but also
provide opportunities for increased profit -- typically 15% to
50% higher than for our basic specs. We offer many levels of
sophistication, from basic railing systems to enclosed gazebos,
decorative pergolas, hot tubs, stone masonry patios and
walkways, built-in storage and planter boxes, and more. Nearly
every option can be quickly estimated by the square or linear
foot, enabling us to value-engineer the project during the
sales process. I have the unit prices memorized, which
encourages the homeowner to come to a quick decision and speeds
the process of getting a signed contract.
Whether we're subcontracting for a builder or working directly
with the homeowner, I always consider how the deck will
complement the appearance and improve the function of the home.
Many homeowners have trouble visualizing an unbuilt project
from sketches or plans, so I've developed a digital
presentation portfolio for my laptop that contains images of
over 500 of our projects. Looking over those images often helps
customers focus on the types of solutions that might work best
for them. The photos also illustrate the importance of matching
the style of the deck to that of the home, and how a
well-designed outdoor leisure space can unite the house with
the landscape.
This approach seems to work well -- our closing rate in this
region's high-end market is better than 50%, and after giving a
presentation I often find that the budget has taken a lower
priority in the overall plan.
Dollars for Details
You don't make money by building the deck shown on the Yes You
Can TV channel. Details sell decks, so I charge for the details
as separate line items.
For example, the posts in our standard railing system are
visibly bolted to the exposed face of the band joist, but we
also offer an optional post detail that embeds their bases in
the deck surface (see Figure 1). The square-foot cost of our
basic deck is based on the externally mounted posts. If the
customer wants to upgrade to the embedded posts, we charge an
additional $20 per linear foot of railing. If the customer
selects our 6x6 cedar post option, which includes a decorative
finial cap, chamfered corners, and a base molding, we charge
$180 per post.
Figure 1.In an optional upgrade to the standard
bolt-on post system, the deck boards are cut flush with the
girder, and 2x4 cleats are nailed between the posts (bottom
left). A 2x10 finish band joist is then fastened to the faces
of the posts, followed by a 2x8 laid flat and notched around
the posts (top). The embedded posts have a strong visual
connection with the deck, while the overhang at the band joist
creates an attractive shadow line (bottom right).
We also offer a broad range of railing options, from the
upscale Chippendale style to the relatively modest Madison
Colonial version (Figure 2). The latter isn't much more
difficult to assemble than the base-priced
square-baluster-and-rail system, but it provides a higher
profit opportunity. If your average markup is, say, 35%, adding
such higher-priced options can easily bump it to 50% or
more.
Figure 2.The author's base-priced deck uses a
square-baluster-and-rail system, but a broad range of
additional styles are available for a variable upcharge, which
is calculated by the linear foot. The ornate Chippendale
railing (top) is a premium-priced option, while the Madison
Colonial (bottom) is a more modest upgrade.
