Building Better Decks, continued
Framing. Whenever decking
boards deflect underfoot, a deck can seem unpleasantly flimsy.
To ensure a solid feel, we usually frame our decks with 2x10
joists on 12-inch centers.
We typically run our decking diagonally. Trex is a dense,
flexible material. Although you can special order it in
virtually any length, it becomes impractical to handle in
lengths over 20 feet. Butt joints in decking are ugly, so I
purposely break the deck surface into pattern sections limited
by the maximum plank length and separated by inlet strips --
full-width 2x6s that all the planks in an area die into (Figure
7).
Figure 7.Running the deck boards diagonally
eliminates unsightly butt joints. The layout is planned so that
no individual board will be longer than 20 feet (above). Joists
are spaced on 1-foot centers to provide a stiff surface
underfoot. Where adjacent diagonal runs meet, an inlet strip,
fastened to blocking between joists (right), provides a
pleasing transition.
A 2x10 finish band wraps the perimeter of the deck framing and
conceals the joist end-nails.
Working with Trex. Because
Trex doesn't have the warping tendency of solid lumber, heavy
fastening isn't needed. Originally, our specs called for the
decking to be screw-fastened on alternating sides of each
board, one screw per joist, to minimize the pattern of the
fasteners. But last year, the county stepped in and required
double fastening at every joist, so that's now our standard
method.
A Quik Drive screw gun automatically sets proprietary
square-drive, ceramic-coated trim-head screws below the surface
(Figure 8). This leaves a little eruption of material, or
"mushrooming," around the hole. While one worker screws the
decking, another follows behind and hammers the mushrooms
flush, effectively concealing the screw heads. To create a more
finished appearance, we also use a router to radius the edges
of all butt joints and any place where the decking changes
direction.
Figure 8.The decking is fastened with trim-head
screws, which are buried slightly below the surface of the
composite decking. Each screw creates a small "mushroom" that
is hammered flat to conceal the screw head.
Solid wood decking. We offer
solid-wood decking as a higher-priced (and more profitable)
upgrade. On those jobs, we use ipe, a tropical hardwood, and
fasten it with Eb-Ty concealed connectors (Eb-Ty, 888/438-3289,
www.ebty.com). The Eb-Ty connector is an
oval-shaped plastic wafer designed to fit in a standard biscuit
slot cut into the edge of the plank. We save some serious time
by ordering the 5/4x6 ipe planks premilled with a running
groove on both edges, replacing the biscuit cutter entirely
(Figure 9). But installing ipe still takes longer, because each
connector must be individually screwed to the joist
beneath.
Figure 9.Tropical hardwood decking is fastened
with the Eb-Ty connector system, which uses a slot-mounted
plastic biscuit. Rather than cutting individual slots with a
biscuit jointer, the author increases productivity by ordering
deck boards with premilled grooves.
Railing posts. We make most
of our rail posts from 4x4 cedar, because pressure-treated
posts tend to split and check as the lumber dries out. We
occasionally use pressure-treated posts as a budget concession
but only after warning the customer to expect those types of
flaws. To locate the posts along the deck's perimeter, we
divide each side of the deck into equal segments of 5 feet or
less.
To make post installation as efficient as possible, we cut the
4x4s to a standard 45 1/2-inch length before squaring a line
across each at the level of the deck surface. We then drive a
hanger nail partway into the post, just above the line (Figure
10). This nail helps hold the post at the proper height while
it's plumbed and temporarily toe-nailed in place. Once all the
posts have been positioned in this way, each one is drilled for
a pair of 1/2-inch carriage bolts spaced on either side of the
centerline and as far apart vertically as the joist depth will
allow.
Figure 10.A temporary "hanger nail" driven into a
precut post at the level of the deck surface provides temporary
support while the post is tack-nailed in place before bolting
(top). To provide a simpler, stronger installation, posts are
paired at either side of angle transitions and corners. The
4-inch gap between posts corresponds to the standard baluster
spacing (bottom).
We place a full post at either side of every corner and
transitional angle, leaving a gap between them approximately as
wide as the maximum 4-inch gap between balusters. This is
structurally stronger than relying on a single post, and it
gives a distinctive and substantial look to the railing
system.
Railing assembly. We like to
limit railing sections to maximum 5-foot lengths. Longer
segments allow too much lateral deflection under loading and
may also require awkward-looking intermediate support between
deck and subrail to prevent sagging. After bolting the posts in
place, we measure between sections and assemble a section of
railing to fit. Our most popular railing systems include a top
and bottom railing separated by the balusters.
Kids like to climb up on the horizontal subrail of a baluster
railing to peer over the top. But all that hopping up and down
soon separates the subrail from the balusters. To counteract
that, we screw the center and end balusters through the top and
bottom rails. That's much more effective than hoping kids won't
be kids. The remaining balusters are secured with finish nails,
which leave smaller, easily filled holes.
We always fill all fastener holes and sand and stain the
railing systems. If the customer elects to use pressure-treated
railing components, I recommend a darker finish color to better
conceal the inevitable cracks and checks in the lumber. Lighter
colors only highlight the defects.
Jim Craigis the owner of Craig Sundecks &
Porches, in Manassas, Va.
