by Jim Craig
My company specializes in decks and porches. We keep ten
two- to three-person crews in the field and build more than 90
screened porches every year. To compete against the many superb
craftsmen in my area, we've had to develop methods and
construction details that enable us to work efficiently and
make a profit but still produce a porch that says quality.
Premium Materials
For starters, I always use top-quality materials, for a couple
of reasons. First, using premium materials reduces the risk of
callbacks and warranty issues. Second, it tells my customers
that I'm concerned about the longevity of my product. And
because the materials cost more and have a reputation for
quality, the markup yields a greater profit percentage than
more conventional materials would.
. We use
Madison Wood Preservers' (540/948-6801;
www.madwood.com) pressure-treated southern
pine for all of the structural floor and enclosure framing, and
for the newel posts and railing systems. Madison includes a
water repellent in the treatment process to retard moisture
absorption and to resist the effects of weathering.
Primed trim. We use
pre-primed pine for all of our painted trim. This lumber is
coated on all sides with an oil-based primer, and all minor
defects and knots are filled and sealed with an exterior-grade
filler to prevent sap streaking and bleeding. We apply two
topcoats of latex trim paint in the field.
Trex. We use this
wood-plastic composite lumber for the deck surfaces outside our
screened porches, as well as for rail caps. It's good looking,
machines easily, and cuts down on maintenance chores. Trex
decking (800/289-8739; www.trex.com) is available in 5/4 and 2-by
profiles; we prefer the more substantial look of the 2-by
stock.
Flooring to Keep Bugs Out
Many builders screen the underside of the porch deck or
install a screened skirt panel around the porch perimeter to
keep insects out. We prefer to use Madison's C-select 2x6
tongue-and-groove boards for a solid, gap-free porch floor (see
Figure 1). The product we use is kiln dried after treatment,
which eliminates the warping, twisting, and splitting common
with ordinary wet PT lumber.
Figure 1.The author installs 2x6
pressure-treated T&G decking to prevent insects
from entering between the floorboards of a screened
porch. The decking is blind-nailed through the tongue
to conceal the fasteners. |
The boards are reversible, with a square-edge finish on one
side and a V-groove edge on the other. We typically install the
boards diagonally across the joists, V-groove up, and
blind-nail the boards through the tongue to conceal the
fasteners.
There's a good reason I run my decking diagonally. Whenever
you run decking perpendicular to the joists, you end up with
scattered butt joints, which degrade the deck's appearance. By
running the decking in opposing diagonals from a central point,
you can cover a large surface with no end-butts. It's a clean,
stylish look.
If a sundeck surrounds the porch, the two structures will
share a common floor frame. I use gapped 2x6 Trex decking for
the outside portion. To back the seam where the Trex meets the
T&G decking, we install 2x6 PT blocking on the flat between
joists, flush with the top edge (Figure 2).
| Figure
2. Two-by blocking, installed on the flat
between joists, supports the transition between the
diagonally installed porch and Trex sundeck
surfaces. |
