Building Screen Porches, continuedFloor framing. Whether
we’re building a deck or a porch, we run the floor
framing on 12-inch centers. Considering that we always use 2-by
decking, that may seem like overkill when 16-inch, or even
24-inch, spacing would be acceptable. But 12-inch centers
provide a stiffer platform to build the porch on, particularly
if the porch structure is set in from the perimeter of the
overall deck framing by several feet. I’d rather not have
a cluttered-looking forest of posts and pilings below the deck
to support the structure.
The added weight of the 2-by surface material — up to
double the dead load of 1-by or 5/4 decking — also makes
it advisable to beef up the framing. I run my Trex decking on
the diagonal and screw it down at alternating edges to reduce
the frequency and appearance of surface fasteners. The closer
joist spacing keeps the screw pattern tight. Diagonal decking
increases the distance that the board must span between joists,
so, again, the closer spacing offsets this effect. And although
16-inch spacing may satisfy the code and my customers might not
notice the difference, my floor systems are stiff and rugged
— no one has ever complained to me about a
springy-feeling deck.
Framing the Enclosure
We assemble the pressure-treated porch enclosure system on the
deck, using 4x4 uprights to define the openings, a 2x4 bottom
plate, and a 1x4 top plate. Our stock black aluminum screening
comes in 5x100-foot rolls, so I design the porch with
5-foot-maximum spacing between the upright centerlines.
We have a standard 2-8 x 6-9 wooden screen door that we use
on nearly every porch. To keep all of the openings at a uniform
height around the enclosure, we cut all the uprights equal to
the finished height of the door, plus swing clearance.
Including the bottom plate, the resulting opening height is 6
feet 11 inches. A 2x4 stretcher at the head of the door opening
compensates for the height gain of the bottom plate and
provides a backer for the finish trim.
On top of the 1x4 top plate, we build a continuous box beam,
using a pair of 2x6s flush with the outside of the 3
1/2-inch-wide plate and capped with another 1x4 (Figure 3). We
shoot all of these components together in place with 12d
galvanized nails. There tends to be some discrepancy between
the width of a 4x4 and the width of a 1x4. Because the
screening and trim boards will be applied to the exterior face,
we're careful to keep all of the framing flush to this
plane.
Figure
3. A box beam lintel consisting of 1x4 plates
and 2x6 sides caps the 4x4 posts and runs the entire
perimeter of the porch enclosure. |
Building the Roof
The roof configuration depends on the porch design, which is
keyed to the style of the home we're working on. One detail
that we use on a straight gable roof has become something of a
signature for us. We build what I call a flying gable, which,
aside from being attractive, has an important function (Figure
4). Water will penetrate only about a foot or so into the porch
along the eaves during a rain, but it can penetrate much deeper
through a high screened gable. The projecting "prow" of our
flying gable provides a deep overhang that keeps the interior
space drier.
Figure
4. The author's signature "flying gable" roof
helps keep windblown rain out of the porch. |
We use treated lumber to frame the roof, too. The rafters
rest directly on the 2x6 box beam. If the rafters are to remain
exposed on the interior side, we use 5/8-inch T1-11 plywood
channel siding, finish face down, to sheathe the roof. The
siding provides a finished appearance inside and an adequate
nail base for the roofing (it's thick enough to prevent
3/4-inch roofing fasteners from penetrating through to the
interior). For a more formal interior, we'll frame a flat
ceiling and finish it with clear fir T&G
edge-and-center-bead paneling. We give the fir three coats of
clear urethane finish, or prime and paint it to match the trim
of the existing home — either way, it makes a beautiful
ceiling.
Roofing. We generally use
asphalt shingles on the roof, though occasionally we hire a
metal roof specialist to install a standing-seam prefinished
metal roof.
Railings
Our typical porch railing system consists of a 2x4 sub- and
top-rail with 2x2 square balusters. The balusters are beveled
at each end and screwed to the wide face of the 2x4s on 4-inch
centers. The 2x4 rails are nailed to the inside face of the 4x4
posts, mitered at inside corners. The balusters thus finish up
2 inches inside the outer face of the enclosure (Figure 5). We
cap the subrail with a Trex 2x6, notching it fully around the
4x4 uprights. The outer edge of the rail cap ends up flush with
the exterior post face. Wider than the 4x4 posts by 2 inches,
the 2x6 cap rail overhangs the 2x4 subrail by 1/2 inch on the
interior side of the enclosure.
Figure
5. Surface-installed rails and balusters
simplify construction and protect the screening from
damage by children and pets. Because the screening
doesn't contact the railing or balusters, they are
barely visible from outside. |
An upgrade rail system consists of a colonial profile
pressure-treated top-and shoe-rail, installed on-center between
posts. The balusters fit into dadoed grooves in the
rails.
