Ground-Source Heating & Cooling Gets Better
Although they're still far from familiar, ground-source heat
pumps have been installed for more than 30 years throughout the
U.S. Also called geothermal heat pumps, they are recognized by
the EPA and the DOE as the most efficient heating and cooling
systems available today.
"Geothermal heat-pump technology offers a renewable energy
solution that's right for almost any home," says Gemma Tiller,
owner of Air Brokers Hvac, LLC, based in Branson, Mo. "Thermal
energy is harvested from the earth and transferred into
buildings by a heat pump that provides heating and cooling."
Despite misconceptions about climates that are too cold,
geo-thermal technology can be used anywhere in the U.S. and
Canada, Tiller says.
A ground-source unit works like a conventional heat pump to
cool a home in the summer and heat it in the winter, but is far
more efficient. Conventional heat pumps use outdoor air as the
heat source and heat sink. Unlike soil, air provides no
reservoir of heat, is a poor conductor, and is subject to
extreme temperature fluctuations, all of which defeat system
efficiency: When the most heat is needed, the outside air is
coldest, and the converse is true for cooling.
According to Monte Jefferson, president of Home Energy, Inc.,
a geothermal installations firm based in Wendell, N.C., "The
key difference between an air-source heat pump —which
can't heat a building efficiently when outdoor temperatures dip
below 30°F — and ground-source is that the
ground-source unit harvests the stable 50°F to 60°F
heat of the earth, transferring this virtually endless supply
of thermal energy into the home. In the summer, it transfers
excess heat from inside to the earth."
Pushing Efficiency Limits
After extensive research, homeowners John and Linda Cavanaugh
decided to install a geothermal heating and cooling system in
their new home in coastal New Hampshire. The type of system
they chose — called direct exchange — is at the
cutting edge of ground-source technology and is currently
offered by two leading geothermal companies, ECR Technologies
and American Geothermal.
The Cavanaughs have tracked their energy use for heating,
cooling, and domestic water since February 2002 with a separate
electric meter. Though their system, an ECR EarthLinked heat
pump, cost approximately 50 percent more up-front than
conventional heating would have, they calculate that this
difference has already been paid back, thanks in part to a
utility rebate that helped subsidize the installation.
A direct-exchange heat pump is notably different from the
typical water-source geothermal system, which exchanges the
earth's thermal energy through water distributed in vast
networks of plastic tubing. Direct-exchange technology
accomplishes thermal transfer at much higher operational
efficiencies because it eliminates one complete heat-exchange
process. Also, because direct-exchange uses a much smaller
"earth loop" (or "geo field"), it requires much less disruption
of the property, making it ideal for retrofits (see Figure
1).
Figure 1.Because direct-exchange technology is so
efficient at collecting the heat of the earth, installations
are possible even on small lots. While trenches or pits are
less expensive, drilling — either vertically or at an
angle — makes it possible to work around ledge or in
tight quarters.
Gemma Tiller has installed various types of geo systems, but
she prefers direct-exchange technology because of the higher
efficiency it delivers and the greater flexibility she can
offer for installation of the earth loops. "The newer
technology extracts heat with little disruption to the
surrounding landscape and at such high operating efficiencies
that it makes payback on the investment faster than ever
before," she says.
Installed costs are about the same for direct-exchange and
water-source geo systems, though both are several thousand
dollars more than a conventional air-to-air heat pump. With
direct-exchange systems, however, small-diameter drilling for a
geo field can achieve near "surgical" insertion of the ground
loops, accomplishing the task quickly and with much less
disturbance to the surrounding landscape than is the case with
water-source systems.
How Direct Exchange Works
Most geothermal systems operate at ranges of 250 percent to
350 percent efficiency, notes Jody Hoffman of Hoffman
Mechanical in Mechanicsburg, Pa., who has installed many types
of geothermal heating and cooling systems over the last 20
years.
"That means these systems supply up to three-and-a-half units
of heat for every unit of electrical energy required to operate
it," Hoffman says. Direct-exchange systems perform even better,
"with system efficiencies up into the 400 percent range,
conservatively. Add the available options for installation of
the earth field, and direct-exchange is a great choice for many
existing homes."
Typical water-source geothermal systems rely on plastic piping
to transfer a water-antifreeze solution through a plastic loop
and an intermediate heat exchanger, where efficiency is
lost.
By contrast, direct-exchange technology circulates refrigerant
through highly conductive copper earth loops that are inserted
into small-diameter boreholes of 50- to 100-foot depths, then
embedded in sand or a protective thermal grout that enables
direct transfer of energy with the earth (Figure 2).
Figure 2.Rather than PEX tubing, which is used in
conventional geothermal heating, direct-exchange systems use
copper for a highly efficient heat transfer. (In some cases,
corrosive soils may prevent installation.) Normally, the copper
is protected by sand, which is installed in a slurry to ensure
good coverage and optimum heat transfer. In areas where
excessive groundwater might pipe away the sand, a special grout
is used instead.
