- Q.Is there any advantage to
installing storm windows over low-e, gas-filled
windows?
A.The storm window
will always add to the insulating value, but it may
be difficult to justify economically. Heat loss is
inversely proportional to R-value. Each additional
R-value is worth less than the preceding one.
Installing a storm window over a single glazed
window will raise the R-value from about 1 to 2,
cutting heat loss by 50%. If the prime window
already has R-4 insulated glass, however, raising
the R-value to 5 will only save 20% of the heat
lost through it. If the prime window has a
center-of-glass R-value of 8, which seems to be the
best available today, the gain would only be 12%.
If the storm window is installed properly, it
should reduce infiltration, as well. Here again, if
you install the new window over a leaky, old sash
you’ll get more of an improvement than if
you install it over a new, well-sealed
window.
