Kitchen & Bath: Prepping Wood-Framed Floors for
Tile
The long-term success of any tile floor installation depends
on a number of factors: the adhesive bond that secures the
tiles, the setting bed on which the tiles are installed, the
structure that holds everything up, and a grid of flexible
movement joints that help isolate the installation from normal,
expected structural movement. Skimp on any one of these, and
the installation is likely to fail.
This article will focus on the prep work that's required
before any tile materials are installed. I will also limit the
discussion to wood-framed floors -- solid-sawn or wood I-joists
with plywood subflooring -- where problems with cracked tile
are common.
Designing for Deflection
The best tile guide is the Handbook for Ceramic Tile
Installation, published and distributed by the Tile Council of
America (see "For More Information," at the end of this
article). It costs only a few dollars but contains the
practical information designers and builders need to ensure
that the tile work will be done properly. Keep in mind when you
use this guide that the details shown are minimum standards --
they represent a point below which the installation may fail.
There is always room to improve the strength and durability of
your installation.
The Marble Institute of America references the TCA Handbook as
a guide for installing stone tiles but amends it with
appropriate changes for stone tiles. As an example, the maximum
allowed deflection for ceramic tile is L/360 (see Figure 1).
This amounts to approximately 1/2-inch maximum allowable
deflection over a 15-foot span. By contrast, a particular stone
tile may require L/480, L/720, or even L/1080! The properties
of many natural stone tiles can change radically -- even within
a single tile -- and therefore they require a stiffer setting
bed. Most ceramic tiles, however, are manufactured to specific
minimum standards, resulting in consistent properties
throughout the tiles.
Figure 1.The tile industry limits the deflection
of floors receiving ceramic tile to 1/360 of the span. This
amounts to approximately 1/2 inch of allowable deflection for a
15-foot span. For stone tiles requiring an L/480 installation,
a 3/8-inch deflection is allowed. Some natural stone tiles may
require an L/720 limit, or even L/1080.
Uniform deflection is the overall distance a
floor's surface is depressed when weight is applied and is a
function of the strength of the joists (Figure 2).
Concentrated deflection is the movement that
occurs on a setting bed surface located between two neighboring
floor joists and is a function of the strength of the
subflooring and the joist spacing. It pays to shop carefully,
since some engineered floor systems that claim to meet the
L/360 criteria do so only for uniform deflection and may fail
to meet the criteria for concentrated loads.
Uniform Loading vs. Concentrated
Loading
Figure 2.Wood floor joists are normally rated for
uniform deflection (left) -- meaning the floor joist's ability
to carry an evenly distributed live load without flexing beyond
a certain limit, typically the span/360. The problem is that
applying uniform live loading to floor design does not account
for points of concentrated loading that may occur between
joists (right), which can cause cracks in tile
floors.
The tile and wood products industries are working on this
issue, and there may eventually be a concentrated load rating
on subflooring and underlayment. Until then, if you're framing
a floor for tile, limit joist spacing to 16 inches and use a
minimum 23/32-inch subflooring.
Structure
It is the structure -- the piers, beams, joists, and studs --
that support the weight of a tile floor installation, plus all
the live load it will carry. For most residential or light
commercial structures, joists should be no less than 2x10s on
maximum 16-inch centers. Reducing the 2x10 joist spacing from
16 to 12 inches or substituting 2x12s for the 2x10s is a good
idea if a wood floor is being built to support natural stone
tiles.
If you have any doubt about a structure you are about to tile,
ask the tile or installation material manufacturers to write a
specification for you that includes a complete structural
detail; or consult your architect or structural engineer.
Isolation membranes. The long spans common in
today's new houses may tax the limits of conventional
installation methods and usually require crack isolation
membranes. I tend to specify a membrane system for any ceramic
tiles installed on spans greater than 12 feet, regardless of
the type of tile, its setting bed, and the structure supporting
it. Membranes also serve a waterproofing purpose (more on
membranes below).
Subflooring
The industry minimum for subflooring thickness is 19/32-inch
exterior-glue plywood (EGP). As you might expect, upgrading to
23/32-inch EGP provides a quieter floor with a more solid feel.
That is the minimum I would use for any tile floor. Two
screw-laminated layers of 23/32-inch are often specified for
more demanding stone installations.
For now, it is still possible to get a relatively good
selection of flat exterior-grade plywood -- but in years to
come? Tiles are now being installed over OSB subflooring, to be
sure, but with mixed results. Failures as well as successes
have been reported. The problems may actually be less OSB than
adhesive. In any case, the wood products industry is very
interested in successfully combining OSB and ceramic and stone
tiles, and in the future, some excellent composite wood panels
will probably be approved for use with tile. Until then,
though, I prefer to stick with plywood.
In the TCA Handbook, a number of approved installations use
plywood subflooring. Pay particular attention to the details
surrounding orientation of the plywood sheets, fasteners,
fastener schedules, gaps between sheets, gaps at abutting or
restraining surfaces, the need for blocking, and closure of the
T&G edge.
To gap or not to gap. Unfortunately, there is no
clear agreement among manufacturers regarding subflooring
installation details. Some manufacturers say you need to leave
a gap; others say you don't. For that reason alone, you should
follow specific directions for each product, rather than
assuming that the instructions for one brand can be applied to
all.
In my opinion, it is essential to do two things when
installing subflooring: Leave a gap; then fill the gap with the
same thinset mix used for placing the backerboard.
The most common failures I've seen on wood subfloors (even
where it seems that everything has been done "right," or
according to manufacturer recommendation) have been cracks that
emanate from tight-fitted joints in the plywood. These cracks
run right through the backerboard if there is one and right
through the tiles. I have seen these cracks with both T&G
subflooring and square-edged, though most of the contractors I
work with avoid T&G in tile areas.
Though I can't cite research to prove it, I believe that
filling the gap with thinset may allow stresses to continue
from one plywood sheet to the next, whereas stresses will stop
(and become apparent as a crack) at a joint that is a void (a
perforation in the substrate).
Underlayment and Membrane
Several tile backers are manufactured specifically for floor
tile installations. These products have a relatively high
compressive strength, but they add virtually nothing to the
structural strength of the installation.
Not all tile backers are alike, and it's important to make a
reasonable, conservative comparison of the available materials.
Cement backerboards are unaffected by exposure to moisture, but
they can transmit water. For that reason, on active wet-area
installations, I always specify a waterproofing membrane, so
that no moisture can pass through the cement boards and
penetrate the structure.
In my opinion, the strongest underlayment for tile -- provided
it's first covered with a waterproofingcrack isolation
membrane system -- is a layer of 23/32-inch exterior-glue
plywood (Figure 3). Screw this to the subfloor with the face
plies running perpendicular to the subflooring and with a 50%
offset between joints. The screws should not penetrate the
joists, only the subflooring. This assembly will be far
stronger than a layer of tile backerboard, which is made of
sand and cement, gypsum, or foam. The only downside is that the
expansion and contraction rate of even the most stable plywood
is significantly greater than that of ceramic or stone tiles.
That problem can be easily overcome, however, with the
application of a membrane system between the tiles and the
plywood.
Figure 3.The author’s preferred setting bed
for thinset floor applications uses two layers of 3/4-inch
plywood and a waterproofing membrane rather than a
backerboard.
In the end, because of normal, expected movement in wood
construction, and because we often use tiles in areas that are
wet or damp, I specify a protective membrane system for most
installations. Sometimes, depending on the brand, the membrane
system may be the underlayment; otherwise, the membrane is
usually applied to the surface of the backerboard, plywood, or
mortar bed.
Every manufacturer of grout and mortar makes a membrane
system, and there are numerous independent brands on the
market. Some are premanufactured sheets, like NobleSeal TS,
while others are composites made of a liquid or paste bonding
agent and a separate reinforcing fabric, like Laticrete 9235.
Latex, sheet rubber, and asphalt-based membranes are also
available.
Flatness Standards
The tile industry standard for flat, plumb, and square is
another problem. In the era when mortar bed installations were
common (and when 4 1/4- and 6-inch tiles were typical), a
flatness tolerance of 1/8 inch in 10 feet was considered
acceptable. (Flatness refers to the differences in height
between neighboring plywood subfloor panels, between
neighboring backerboard panels, and between neighboring tiles.)
If you could get the setting bed flat to within that tolerance,
aligning all the trim and field tiles was relatively simple,
because of the ability of smaller tiles to conform to a less
than perfect surface.
Unfortunately, at the last ANSI A108 standards meeting, the
tolerance was loosened to 1/4 inch in 10 feet, which will allow
the safe installation of 6-inch tiles but doesn't work for the
now popular large-format tiles -- tiles measuring 10 inches or
more.
For that reason, anyone installing large-format tiles up to 14
inches should use, at the very least, the old 1/8-inch
tolerance. For larger tiles, a setting bed surface true to
within 1/16 inch in 10 feet or less is needed. Without the
traditional mortar bed, and its ability to flatten and true an
irregular surface, installations using thin-bed materials need
to be planned before construction begins, to ensure enough room
for a self-leveling compound to true a floor's surface. The
thickness of a typical self-leveling compound ranges from a
minimum of 1/8 inch up to about 1 inch per pour. Some
manufacturers allow for two pours.
Keep the Setting Bed Clean
Finally, after you've gotten all the structural and substrate
details right, it's critical to keep the surface of the setting
bed clean and dust free. This means no foot, ladder, or wheeled
cart traffic until the curing time expires for all the
materials used in the tile installation. If a worker has to get
on a floor that's going to be tiled, the work should be
protected with enough tarps to make sure that no contamination
is deposited on a surface that's supposed to receive tiles or
tile installation materials.
Michael Byrneis a technical consultant, specialty
installer, author, and contributing editor for
JLC.
