By Kelly
Morisseau
Ever experience the frustration of having to design a
kitchen for clients with champagne tastes and a soda pop
budget? You keep a lid on costs by specifying a decent,
inexpensive stock cabinet line. The layout is realistic and
functional, and you feel pretty good about the package. Now, if
only the clients were as happy as you. "Can't you make it more
like this one?" they complain, waving a magazine clipping of a
high-end kitchen remodel in your face. Well, don't grit your
teeth: There are ways that you can infuse some sizzle into your
existing design without upgrading the cabinets or detonating
the budget.
Window Seat
A window seat is a popular amenity because it adds a
functional, custom detail to a conventional kitchen plan. It
doesn't require a lot of space; it only has to be large enough
to allow at least one person to sit comfortably. Many kitchen
spaces have undersized or underused nook areas, perfect for
this type of application. And cabinets under the seat provide
excellent storage for items like puzzles, children's games, and
table linens.
The average person can sit comfortably in a 24-inch-wide
space. A window seat for two people would therefore need to be
48 inches wide. You can create a seat that size by using a pair
of 24-inch-wide wall cabinets, 12 inches high and 24 inches
deep. Why not just use a 48-inch-wide cabinet? There's not
enough support in the center of the cabinet to handle the
weight of one person, let alone two. Sure, you could add a
center stile and bracing, but it's stronger and faster to join
two cabinets.
A standard seat is about 18 inches deep, or 6 inches less than
stock cabinet depth. So if the cabinet construction allows
simple modification, you can cut it down. If the window seat is
installed in a line of cabinets, the resulting recessed
faceline enhances the "cozy nook" look of the seat. Otherwise,
thick back cushions and throw pillows can fill in the stock
24-inch depth (see Figure 1).
Standard seat height above the floor is also about 18 inches.
A 12-inch cabinet on a 4-inch kick, topped by a 4- to
6-inch-thick cushion, brings the total finished height to
between 20 and 22 inches. That's still fine for most users; in
fact, it'll boost a toddler's chin off the tabletop. On the
other hand, a 5-foot-3-inch-tall adult may lose circulation in
the legs at that height, so check all dimensions against your
client's. If a lower, more conventional height is preferred,
simply reduce the height of the toe kick accordingly.
Make the toe kick from plywood or particleboard, with a center
brace to carry the center support through to the floor. Add a
plywood top trimmed with an edge molding. I install the strip
with its bottom edge flush with the plywood panel to create a
lip that prevents the cushion from slipping forward.
The price of this window seat, using a good stock cabinet line
(I work with KraftMaid, Schrock, and Hertco) should come to
about $550 to $700 in materials, mostly depending on the door
style. A final note: Choose cabinet knobs or pulls that won't
snag clothing or limbs.
Baking Table
Function is the key when planning this unit. Case in point: A
client who loves to make pies rolls out the dough to at least
12 to 14 inches and will need two to three times that width to
function comfortably. Add mixing bowls, rolling pins, and
various cutlery and you're looking at a minimum 36-inch-wide
table. To fill the bill, you'll need a 30- to 36-inch-wide desk
drawer unit, the kind that allows for knee space underneath. If
the stock line includes a vanity drawer depth (21 inches deep),
so much the better, as the countertop can then terminate
neatly, with no projection, against standard, 24-inch-deep base
cabinets on either side (Figure 2).
Traditional, turned-wood posts, preferably 3 inches in
diameter by 32 inches high, make nice supports. If the cabinet
line doesn't include posts, substitute square-end stair
balusters or newel posts. (The square end makes it easier to
attach the posts to the drawer box.) Trim the balusters to
length and paint or stain them to match or complement the
cabinets.
The drawer unit will be sandwiched at its front edge between
the two posts. Install the posts 3/4 inch proud of the cabinet
frame, or flush with the drawer front, so they won't project
beyond the overhang of the countertop. Attach the posts to the
drawer unit before you screw it to the wall, so the legs
support the front of the unit during installation. You may wish
to install the legs loosely initially, using oversized pilot
holes in the drawer carcase, to allow for small adjustments to
variations in floor height.
Be aware of the height of your client. The final height of
this table will be 32 1/2 to 34 inches above the finished
floor, depending on the thickness of the countertop -- a good
height for people from 5 foot 2 inches to 5 foot 7 inches, but
a literal pain in the neck for anyone taller. If your client
tops 5 foot 7, don't drop the baking table at all -- stick with
a standard, 36-inch-high working surface.
The baking table installs between common base cabinets, so
remember to specify finished end panels for the two flanking
cabinets. I build an 18-inch-deep-by-4-inch-high toe-kick frame
in the opening before installing the table, and top it with a
full-width 5/8-inch-by-18-inches-deep plywood or particleboard
shelf. A bead or rope molding on the front edge adds a nice
extra touch.
Thirty-six inches is a long span, especially if the drawer
unit is of frameless construction. To prevent deflection,
reinforce the front edge with a 1-by rail -- or a 2x4 if you
anticipate heavy kneading. Recess the 2x4 slightly and conceal
it with an arched valance.
If you use a 24-inch-deep drawer unit, keep the doors of
adjacent base cabinets in mind, because the low, projecting top
of the baking table may check their swing. Either reverse the
doors to swing away from the table, or specify top drawers for
these abutting units. In any case, you'll want to chamfer the
countertop corners to prevent hip bangs.
The price for this unit may surprise you. All materials,
including the cabinet, turned legs, shelf material, and
valance, cost $75 to $125 less than a standard, drawer-and-door
base cabinet.
End Display Shelves
Custom cabinet installations often feature some variation of
an open-shelf display unit at island, peninsula, and base
cabinet ends. The good news is that stock cabinet lines
typically include at least one version of this idea. The bad
news is that they're almost never what the client wants. Here
are a couple of easy ways to solve that problem. Once again, I
use two wall cabinets, of varying styles, 24 inches wide, 12
inches deep, and 15 inches high, or any height combination that
totals 30 to 31 inches, so that, when stacked and mounted on a
toe kick, they'll match the height of the other base cabinets.
The wall cabinets should have both ends finished.
KraftMaid, for example, offers the following 24x15x12-inch
wall cabinet modules: a bookcase with a finished interior and
valance; a standard, closed cabinet; a plate rack; and a wine
rack. Used in various combinations, these four units give you
plenty of possibilities to work with (Figure 3).
Mix-and-matchable wall cabinets provide
plenty of options for terminating an island or peninsula
cabinet. Use door blanks to finish the ends.
Again, build a 4-inch toe-kick frame to support the stacked
and joined cabinets. You can apply a flat decorative molding to
hide the front seam between units and dress up the cabinet
sides by applying false door panels, 12 inches wide by 30 or 31
inches high.
Avoid stacking two frameless door units without a spacer, or
buildup, between them, so that top and bottom doors don't hit.
The same goes for the upper door clearance under a drop-edge
countertop. If the countertop doesn't have a built-up edge, it
may overlap the front of the cabinet by 3/4 inch, effectively
ensuring that no one will ever open the upper doors.
Display cabinets are costlier than other units, ranging in
price anywhere from $900 to $1,500, depending on door style,
type of units used, and whether you apply false door
panels.
What your clients want is some kind of a twist that makes
their kitchen stand out. So use your imagination and see if
they don't end up saying, "That's what we're looking
for!"
is a Certified Kitchen Designer,
Certified Bath Designer, and Certified Interior Designer at
Main Street Kitchens in Walnut Creek, Calif.
