Products
JLC 's
Products
by Dave Holbrook
Hot Wiring
An outlet device should not serve as a splice for the wiring
in a continuous circuit; it should be tied in to the wiring
via a "pigtail" from a
common wiring terminal.
Term-a-Nut Pigtail
Connectors make it simple,
combining a twiston
connector, flexible
lead, and spade terminal
in a one-piece
wiring solution. The
connector eliminates
wire stripping and
forming, and provides
neat, uniform splicing
inside the box. The
connector is sold by
distributors in seven different size combinations; prices vary.
Contact: Ideal Industries, Becker Place, Sycamore, IL 60178;
800/947-3619; www.idealindustries.com.
Sword in the Stone
Concrete work is hard and
heavy. Wouldn't it be swell if
you could just pull up your stakes
and go home? That's the idea
behind StakeSleeves, a
