Lead-Safe Remodeling With Dust-Containment and Meticulous Cleanup
Dust-containment and meticulous cleanup are the keys to protecting workers, clients, and especially young children
12 MIN READ
As a restoration carpenter, old house owner, and parent, I’ve been concerned about lead paint for years. Intact lead paint generally poses no threat, either to workers or to the occupants of a home; but lead dust that’s unleashed during remodeling activities can have serious consequences, especially for very young children. Fortunately, the precautionary measures that remodelers need to take are mostly commonsense, especially for anyone who already takes dust-control seriously.
Why Worry?
If it gets into the bloodstream, lead can unleash severe health problems — high blood pressure, anemia, kidney damage, memory loss, and impotence, among others — for adults. But lead is most harmful to children under the age of six because it interferes with brain development, which can have tragic, lifelong consequences. Lead is most easily absorbed into the bloodstream through the digestive system. Infants and toddlers are most at risk because they crawl on the floor and put everything they touch in their mouths; pets can be lead-poisoned in the same manner. Workers who disturb lead paint need respiratory protection, especially when doing demolition or other high dust-generating activities, but they also must be especially careful to wash their hands before eating, drinking, or smoking.
All Painted Surfaces Are Suspect
Lead-based paint was officially outlawed for residential applications in 1978, but its use had steadily declined since 1950. So a house that was built between those years might have little or no lead, but one that was built before 1950 probably has plenty of it. Back in the day, lead-based paint was routinely applied to all of the wood surfaces (interior and exterior), but only some of the plaster. Plaster surfaces in kitchens and baths were routinely coated with a “scrubbable” glossy, lead-based paint. The plaster in closets oftentimes got a coat of lead (under the assumption that the long-lasting lead-based paint would enable these surfaces to be painted once and forgotten). Typically, the other plaster surfaces in a house were not covered with lead-based paint, but who knows what could have been done over the course of 50 or a hundred years?
Testing. The only way to know for sure where lead paint may be lurking is to test for it. This can be tricky, however, because so many years have passed since lead paint was the norm that the topmost paint layers are usually lead-free. If you use a do-it-yourself test kit, you must be sure to cut through every layer of every painted surface in question or you’ll likely get a false negative result. A more accurate and less invasive option is to hire a certified lead inspector (at a cost of several hundred dollars) to test all the surfaces using an x-ray device that will detect the presence of lead no matter how deeply hidden.
Sally Odle, of Safe Homes Inc., a lead consulting firm in Waterbury, Conn., advises remodelers like me to save their money, assume that all of the painted surfaces have lead, and take the necessary precautions. “By working lead-safe, you’re going to create much less of a mess and your customer is going to be a lot happier,” she says.
Isolate the Work Area
If I’m beginning a remodeling project in which significant dust will be generated — by activities such as removing plaster, exposing wall cavities, or stripping paint — I try to completely isolate the work zone from the occupied area of the house. This practice not only guarantees that all of the mess is contained, but it also prevents inquisitive children from sneaking into the work space.
6-mil poly and duct tape. If I’m lucky, the containment process might be as simple as locking an interior door and duct-taping its edges, or covering an open passageway with 6-mil plastic sheeting and sealing all four sides with duct tape. For larger projects or houses with open floor plans, I may have to erect a temporary partition wall and wrap it with a membrane of 6-mil poly. (For more information about erecting an effective dust partition, see Protecting the Job Site, 4/04.)
If the house has a forced-air hvac system, I shut it down (if possible), and seal up the registers in the work area (especially the cold-air return) with plastic and duct tape. To contain the worst of the debris, I cover the floor with a layer of 6-mil plastic and tape the edges to keep it from sliding.
In a perfect world, the barrier between occupied space and job site should remain intact until all of the dust-generating activities have been completed and the site has been thoroughly cleaned. During the dusty phase of the job, workers would access the site directly through an exterior door (or possibly a window); and they would use separate bathroom and hand-washing facilities.
However, forcing workers to climb in and out of a window is bad for morale (even with both sashes removed), so Dennis Livingston, a contractor and lead consultant from Baltimore, schedules his remodeling projects to ensure that all of the dust-generating work gets done upfront; “Do all of your dirty work first,” he says. “Then clean the place immaculately and you can treat the job like any other remodeling project.” To be successful, a policy such as Livingston’s requires cooperative subcontractors — plumbers and electricians who make sure that all of the holes they need to punch in the walls are done in advance, and painters who are willing to schedule an early visit to the job if their prep work will disturb lead paint.
To further compress this dirty phase of the job, painted items like doors, windows, and trim that need stripping or repair can be removed to an offsite shop or sent to a paint-stripping specialist. Messy repairs, such as planing doors and reglazing windows, can also be accomplished by setting up a temporary work space — securely walled-off by plastic sheeting — in a garage or a basement. At the end of the job, this “dust room” would then be cleaned just as carefully as the work site.
Partial Isolation
On some jobs, I’ve found it impossible to completely isolate the work area from the residence. If workers have no choice but to pass through occupied territory to get to the job, lead consultants recommend covering the pathway with a plastic drop cloth that’s carefully folded (dirty side to dirty side) at the end of each day and routinely cleaned with a HEPA vacuum. I’ve found plastic to be too slippery for pathways, so I break this rule by using a canvas drop cloth, but I’ve marked the top (dirty) side with a bunch of bright red Xs to ensure that the clean side always rests on the floor.
Doorways. In a case such as this, the entrance to the job could be through a swinging door that’s fully sealed on every side with some type of weatherstripping; but it’s also possible to fashion an effective airlock using duct tape and two sheets of 6-mil plastic. On the days when dust is flying, workers should always remove their protective garments or vacuum the dust off of their clothes and shoes before leaving the work space.
Worker Protection
Containing lead, as well as all of the other nasty stuff — asbestos, plaster, coal dust, dead bugs, animal droppings — that can get stirred up during an old-house remodel, is the best way to protect homeowners. But the best way to protect workers is to minimize the amount of dust that gets stirred up in the first place.
Working wet. The simple way to prevent dust is to spray a fine mist of water onto painted surfaces before scraping, sanding, or dismantling them. A 1-quart spray bottle is perfect for small-scale paint scraping or trim removal. A 1- or 2-gallon garden sprayer is a better choice for demolition or clean-up — misting debris before sweeping or shoveling is an extremely effective dust remedy.
Vacuum-attached power tools. Saws, grinders, planers, routers, and sanders specialize in kicking up dust. But fortunately, the best of these tools are now equipped for dust extraction. When attached to a high-efficiency tool-operated vacuum, the vast majority of the dust is contained at the source. “These days, everything I do attaches to a vac,” says lead consultant Sally Odle.
Respiratory protection. By now, everyone knows that a cheap paper dust mask offers no protection from hazardous airborne dust. If you’re a demolition specialist or a painter who’s routinely exposed to lead dust, you need to wear a properly fitted, half-face respirator that’s equipped with HEPA (purple) filters. If you remove paint using heat or chemicals, your respirator must be equipped with organic vapor filters (yellow) or with two-stage filters (purple and yellow) that offer both types of protection.
Nobody likes to wear a respirator; and fortunately, most remodelers don’t have to. If your work brings you into contact with lead dust on an occasional basis, all you need is an N100 series disposable respirator (3M Co.; 800/243-4630; www.3m.com). This nifty device meets the same HEPA filtration standards as a purple-filtered respirator, but it’s much more comfortable. Although a single mask costs about $8, it should last a worker for the duration of a typical job.
Facial hair. To provide effective protection from lead or other hazardous dust, a respirator must seal tightly against the face. A tight seal is not possible if the respirator is worn on top of facial hair. Although a full beard is unacceptable, a mustache or a tight goatee that fits inside the seal of the respirator is fine.
Clothing. Tyvek coveralls are another item that nobody wants any part of. They’re hot and unflattering, but they can be convenient, especially when doing heavy demolition. Workers who don’t wear Tyvek should change out of their lead-soiled clothing before entering their homes — or before driving home, if their children ever ride in their work vehicles. They should also wash their clothes separately from those of the rest of the family.
Clearing the air. Some remodeling contractors set up negative air machines that filter the air before exhausting it to the outside. There’s nothing wrong with using these devices; they do an excellent job of capturing lightweight dust such as asbestos and fiberglass, but they haven’t proven very effective with lead, which tends to settle to the ground quickly. Other air-clearing devices, such as unfiltered squirrel cages or window-mounted fans should not be used, however, because they just pour the dust onto the lawn.
Cleanup
Experts tell me that vacuum cleaning may not suck up every bit of lead dust — especially if you’ve used water to control the dust — so the final clean-up requires washing as well as vacuuming. The standard procedure goes something like this: After carefully folding and discarding the plastic floor covering, slowly vacuum all horizontal surfaces using a HEPA or other high-filtration vac; pay particular attention to crevices and cracks between floorboards. Finally, you should scrub all of the horizontal surfaces with a strong household detergent and empty the dirty rinse water into a toilet, never a sink or bathtub.
Before the barriers come down, you can verify the effectiveness of your cleaning process by swabbing a section of the floor with a wet wipe and sending it to a testing lab. If your clients have young children and are worried about their exposure to lead, you might choose to have this testing done by a third party. (To locate a qualified lab or third-party testing service, visit www.leadlisting.org.)
Small Jobs
Fortunately, lead paint is not so big a threat that every job needs to be encased in a cocoon. The lead dust or paint chips that might be released when removing a window sash, taking out a door panel, or replacing a few pieces of trim can be contained by a plastic drop cloth that extends 5 feet out in every direction from the work surface. Any furniture or personal items within these boundaries should be moved or covered with lightweight plastic. The plastic floor cover can be reused, if you’re moving from one place to another, as long as you fold it carefully (dirty side to dirty side) and unfold it just as carefully. It’s a good practice to take off your shoes before you step off the plastic, or vacuum them clean.
Exterior Paint
Unless you throw a tent over the whole house, it’s not possible to fully contain the dust that’s generated by paint preparation. So every activity must be planned to minimize dust generation. Power washers, if used at all, should only be used by a skilled operator to clean the painted surface, never to remove loose paint. Cover the ground and plants with 6-mil plastic that extends at least 10 feet out from the base of the house. On sunny days, use a gardening film such as Weed Block, which is less likely to burn plants.
Paint removal. Don’t use unshrouded power tools, belt sanders, or torches to remove paint. I’ve had good luck using the Paint Shaver (American International Tool; 800/932-5872; www.paintshaver.com), a shrouded grinder that’s attached to a tool-actuated vacuum.
Recently I also started using the Silent Paint Remover (Viking Sales; 585/924-8070; www.silentpaintremover.com), which loosens paint using infra-red heat. Stripping paint takes longer with this device, but it’s quieter and less grueling to operate. Respiratory protection should be worn when using either of these tools.
You could also use a chemical paint stripper such as Peel-Away (Dumond Chemicals; 800/245-1191; www.dumondchemicals.com), but you have to collect the rinse water and dispose of it properly.
Minor surface preparation. If most of the paint is intact, I remove the loose patches using a sharp carbide hand scraper. Then I feather the edges of the intact paint using a shrouded random-orbit sander that’s attached to a tool-actuated vacuum.
Tom O’Brien is a restoration carpenter and a freelance writer in New Milford, Conn.
Lead Resources
The National Paint and Coating Association (NPCA) is currently funding a number of free one-day courses across the country to train workers as well as homeowners on lead-safe work practices. To find a program in your area, visit NPCA’s website at www.paint.org.
For more information about lead:
U.S. Department of Housing and Urban Development (HUD) Office of Healthy Homes and Lead Hazard Control
www.hud.gov/lead
National Lead Information Center
www.epa.gov/lead
To purchase lead-safe work supplies:
Aramsco
www.aramsco.com
Tom O'Brien
