Cordless Cut: Makita LXSL01 18-volt LXT Lithium-Ion Cordless Dual-Slide Compound Miter Saw
Ideal for installing flooring or interior trim, the 18-volt LXT lithium-ion cordless 7½-inch dual slide compound miter saw offers accuracy and capacity in a portable design. Weighing just 27.5 pounds, model LXSL01 can cut a 2×12 at 90 degrees and a 2×8 at 45 degrees. The saw delivers 2,200 rpm with a direct-drive gearbox for increased cutting efficiency and less maintenance than belt drives. The LXSL01 offers a 21/16-inch vertical capacity and will crosscut 11¾-inch material at 90 degrees. Makita | 800.462.5482 | makita.com
Lauren Hunter
