Better Pole Sander. The new Football Pole Sander is a simple tool with some significant advantages. Its broad base helps the user cover lots of area quickly and resists tilting and flipping, and its unusual shape eases the task of sanding in tight corners. The sander has a foam pad that protects sidewalls and moldings against dings and scratches while conforming to minor bumps and contours. It costs $40. Diamond Wall, 888/235-4397. www.diamondwall.com
Go to JLC
