Reflective Wrap. If your projects include
flat roofs with exposed ductwork, Flex Clad duct and pipe wrap
could help protect them against the elements. The self-sticking
rubberized asphalt membrane has an aluminum facing to reflect
the sun and a layer of cross- laminated polymers for tear
resistance. According to the manufacturer, the product is
self-healing if punctured with a nail or other fastener and
will adhere directly to metal and to foil-faced foam duct
insulation. It now comes in a 25-mil format as well as the
conventional 40-mil. Available in aluminum, white, gray, and
tan, it costs around $1.10 per square foot. MFM
Building Products, 800/882-7663,
flexclad.com.
Gas Blocker. VaporBlock 20 Plus plastic
sheeting is intended for under-slab applications where
soil-borne gases like radon are a concern. The manufacturer
claims it’s 50 times less permeable than typical
high-performance polyethylene vapor retarders. The company also
says it’s much less expensive than comparable products. A
10-foot-by-150-foot roll costs about $470. For radon blocking,
seams should be sealed with a special foil-backed tape (VBP4VB
Plus Tape) that costs $32 per 4-inch-by-210-foot roll.
Global Plastic Sheeting, 866/597-9298,
globalplasticsheeting.com.
Metal Weld Sealant. Titebond WeatherMaster
Metal Roof Sealant is based on the adhesive that car
manufacturers use to join metal auto-body panels in spots where
rivets would be too unsightly, says the maker. It can be
applied in temperatures as low as 0°F, fills gaps up
to 1 inch wide, adheres to Kynar-coated roofs, and can be
painted three hours after application. Sold in 50 standard
colors, the adhesive has a low enough VOC content to meet the
requirements of most green building programs, says the company.
It forms a permanent chemical bond with the metal, so spills
should be wiped up before drying. A 10-ounce cartridge costs
$5.50 to $6. Franklin International,
800/669-4583,
titebondgreenchoice.com.
Blue Pine. An outbreak of mountain pine
beetles has killed off millions of acres of pine forest in the
Rocky Mountains. All efforts to kill the bugs have failed, so
now the trees are being harvested to reduce the chance of
catastrophic wildfire. The resulting lumber — beetle kill
pine — features a random blue-grey streaking, sometimes
highlighted with reds and yellows, derived from a fungus
carried by the bugs that stains the wood without altering its
properties. Colorado-based GreenWay LLC offers such beetle kill
products as logs, knotty siding, and flooring. Siding prices
range from $0.65 per linear foot for smooth-planed 1x6s to
$1.49 per linear foot for 1x8s with a hand-hewn face.
GreenWay LLC, 888/323-3739,
begreenbuildblue.com.
Packaged Rain Screen. The Siding Vent System
is a prepackaged rain screen for use behind horizontal siding.
It has two components: a corrugated vent that’s installed
horizontally at the base of the wall, and vertical
Sturdi-Strips that are nailed to the wall every 16 inches.
Unlike wood, says the manufacturer, the 1 1/2-inch-wide by
1/2-inch-thick by 4-foot-long strips won’t compress or
split during installation. A box with enough pieces to create a
rain-screen wall at 8 feet high by 36 feet long costs $114.
Cor-A-Vent, 800/837-8368,
cor-a-vent.com.
Disappearing Screens. Made from strands of a
fluoropolymer that are half the diameter of the strands in
standard fiberglass or metal screens, InLighten screens bring
in more light and allow more airflow, says the maker. In fact,
when we compared a sample of this new material to a metal
screen, the difference was striking: The InLighten screen was
far less noticeable than the metal version. The manufacturer
says that the material is as strong as fiberglass or metal and
has a memory that lets it bounce back after being dented. The
product comes as custom-made window screens or in rolls of up
64 inches wide for screen porches. Prices start at $80 per
screen and $5 per square foot for the rolls. WL
Gore, 800/554-4696,
inlightenscreens.com.
