Favorite Drywall Tools & Accessories - Continued
Baker's scaffold. For ceilings that are too
high for a drywall bench, the so-called baker's scaffold may
give you just the boost you need. It's narrow enough to fit
through a door opening, is available in 6-, 8-, and 10-foot
lengths, and it can be adjusted to up to 6 feet high in roughly
4-inch increments. The baker's scaffold provides a nice stable
platform for working on ceilings up to 12 feet high (Figure
4).
Figure 4.A baker’s scaffold rolls easily
through doorways to provide a mobile platform for ceiling work
up to 12 feet high.
Hanging or taping drywall on higher ceilings also requires a
stable work platform. I use metal scaffolding with a minimum
4x10-foot platform that can be adjusted in 15-inch height
increments.
Deadman. A lot of us have used a simple
site-made T-support, or deadman, to help hold a sheet of
drywall tight against the ceiling while it's being attached. A
new version of this device, the Stiff Arm from Falcon, adjusts
for different ceiling heights and locks into place. The extra
support frees up a live person to attach the panel (Figure
5).
Figure
5. The adjustable, locking Stiff Arm deadman provides
temporary overhead support when hanging ceiling
panels.Wall-panel lifters. As I
mentioned before, sometimes a panel needs to be lifted only 1/2
inch or so off the floor. It sounds simple, but without the
right tool it can actually be difficult to accomplish. A foot
lift is a small, metal wedge that works like a see-saw lever.
Jammed under the bottom edge of the panel, all you do is step
on it to raise the panel into place. Both hands remain free to
attach the panel (Figure 6).
A foot lift works like a small lever to boost
lower wall panels into position, leaving both hands free for
fastening.
Stilts. I use stilts primarily for taping and
sanding. Stilts eliminate the need for benches and ladders when
finishing ceilings and walls up to 10 feet high. Stilts allow
for a lot of mobility and, as a result, improve productivity
and the quality of the work.
Fastening Tools
Occasionally, I use nails to attach the perimeter of a drywall
panel. A drywall hammer looks like a hatchet, but it isn't
sharp. I use the blade end for prying and lifting and,
sometimes, if a panel doesn't quite fit, I'll chop at the high
spot to coax the panel into place. Unlike a common framing
hammer with a flat striking face, the convex face of a drywall
hammer leaves a proper shallow dimple without tearing the paper
facing (Figure 7).
Figure
7. Unlike a carpenter's hammer, the convex face on a
drywall hammer makes a dimple in the panel without tearing the
paper facing. The hatchet-like blade is used mostly for
prying.Screwguns. Drywall screws
are the best fasteners for drywall. A drywall screw-gun with a
magnetized Phillips bit is the best way to set the screws,
because the panel is pushed tight against the framing while the
gun zips the screw in to the proper depth. When you apply
pressure to the screw, the tool’s positive clutch
engages; it disengages when the screw reaches its proper depth.
This feature enables the user to lock the trigger in the
“on” position for efficient use. Look for a
well-balanced tool with a comfortable grip, ease of use
overhead, and the ability to set a screw close along the inside
edge of a corner. I use a Grabber 6.3-amp 4,000-rpm Rocker
4063. I also love my Senco Dura Spin cordless self-feeding
screwgun because I don’t have to drag a lead cord around
or constantly reach into my toolbelt for a screw (Figure
8).
Although he often
uses a standard electric drywall screwgun, the author also
likes the convenience of the Senco cordless self-feeding
screwgun.
