Favorite Drywall Tools & Accessories - Continued
Sanding Tools
Sanding is an unpleasant but important part of a quality
taping job. A number of tools make the task go a little faster,
but keep in mind that a quality hanging and taping job greatly
reduces the amount of sanding necessary. Sanding may not be
fun, but it sure is good exercise.
Pole sander. I use a pole
sander on most areas that require sanding. The pole sander has
a rectangular or triangular pivoting head and a 4-foot handle
that gives you plenty of reach and leverage. Heads are
available for hand use, too. I like Warner’s
triangle-shaped hand sander for touch-ups. I can point it right
into a corner or glide it along an inside edge without marking
up the adjacent side.
The abrasives used on pole and hand sanders are available in a
variety of grits. The best choice for finish sanding is 150
grit. You can use a sanding screen or sandpaper, but I prefer
the screen because it doesn't plug up with dust. And when the
abrasive gets worn, you can flip the screen over to expose a
fresh surface (Figure 14). However, as far as I know, pre-cut
sanding screens aren't available for the triangular sanding pad
yet.
A sanding screen or
150-grit sandpaper is the best choice for finish sanding (top).
Screens can be flipped over when the abrasive is worn. The
author uses a variety of pole-mounted and hand-held sanders
(above). Triangular sanding heads are particularly useful in
corners.The dry sanding sponge
(from Warner Tool or Trim-Tex) is made of a dense, flexible
material that is covered with grit. Sizes vary from 3x4 inches
to 4x8 inches. Sponges are available in different grits; some
have beveled edges for getting into tight corners. A fine-grit
sanding sponge is great for small touch-ups after you've
treated the field with a pole or hand sander.
Dust Control
The dust-free sanding tools that I have tried work quite well.
Sand&Kleen makes a sanding attachment for a shop vacuum
that draws the dust into a water reservoir (Figure 15). The kit
costs about $40 and includes the reservoir bucket, 20 feet of
hose, and a hand sander (available from Amerashop). I use a
Wilco dust-free pole sander — with a sealed pivoting
head, an extendable handle, and a vacuum hose — that
costs about $250. Some sanders have an oscillating sanding
head, others are manual, but all involve a vacuum and hose to
draw the dust directly from the sanding head into a
filter.
.Figure
15. This dustless attachment (top) for a shop vacuum
captures nearly all of the sanding dust in a water filter
(above). A temporary dust curtain is useful on remodeling
sites.
A certain amount of touch-up sanding will always
be necessary, so you’ll have to take other precautions
when there’s a strict emphasis on dust control. To seal
off the work area, I use plastic sheeting and Curtain
Wall’s adjustable aluminum poles and clamps to put up an
effective temporary dust
barrier.
Dust mask. Speaking of
dust, to prevent joint compound from reconstituting inside your
nose, don't forget to use a disposable mask with a good seal
that's approved for protection against nontoxic dust and
mist.
