Behind Door Number One
Perching a solid-core door on your foot while you sneak in a
hinge pin is a good way to mash your toes if not to hang a
door. Enter the Doorminator, a heavy-duty rolling cart
that makes supporting and hanging a heavy door by yourself as
easy as dropping in the pins. The cart lifts and positions the
door while spring-loaded hooks hold it steady. A 300-pound,
48-inch-wide capacity should handle just about anything you're
likely to install, and forward, back, and sideways adjustments
make both hanging and removal easy and safe. The Doorminator
weighs approximately 65 pounds and has a swiveling back leg to
negotiate tight spaces and narrow openings. It costs about $400
(plus shipping).
Contact: Telpro Inc., Grand Forks, N.D.; 800/448-0822,
http://www.telprodirect.com.
Stylish Rack
If you're tired of your roof rack whistling while you drive to
work, the TracVan rack system for vans and SUVs might be
of interest. It has an aerodynamic shape to keep wind noise to
a minimum and features wide mounting brackets and damage-free
fastening clips. Four sliding tie-downs keep your ladders or
lumber under control. The aluminum frame is powder coated to
resist corrosion, and concealed fasteners accentuate its
shapely look. The rack can be installed "in seconds," is rated
for 500 pounds, and has a retail price of $209.
Contact: TracRac, Fall River, Mass.; 800/501-1587,
http://www.tracrac.com.
Fancy Pan
A preformed, ready-to-tile shower pan can save hours in
installation time. Here's a new, lightweight polystyrene
shower pan that won't rot or degrade, maintains a
1/4-inch-per-foot slope, and does away with many of the
headaches typically associated with mud jobs and membranes. The
built-in drain connects to either PVC or ABS pipe without
special fittings, and the adjustable square grate simplifies
tile layout, helping to keep cuts to a minimum. Pans cost from
$350 to $575 for standard sizes, and custom sizes and shapes
can be special ordered.
Contact: Bonsal, Charlotte, N.C.; 800/334-0784,
http://www.bonsal.com.
Sweet Switch
A retrofit garbage disposal is easy enough to install on the
plumbing end, but fishing a wire up to a new wall switch can
take a lot of time and patience. Simplify the wiring process by
mounting a Sinktop Switch on the sink deck, and save
fishing for the weekend. The switch comes in white or chrome
and the list price is $67.
Contact: In-Sink-Erator, Racine, Wisc.; 800/558-5700,
http://www.insinkerator.com.
Family of Routers
A new collection of routers has joined the familiar
yellow and black family of power tools. The new offerings
include fixed, D-handle, and plunge platforms, with 13/4- or
21/4-horsepower motor packs. All have features that are meant
to edge out the competition. A quick-disconnect motor cord
allows those who favor a trigger-operated D-handle to plug in
to the motor without nine feet of cord tied to the housing. All
three router styles feature flat tops, micro-fine depth
adjustment, quick-release motor latches, and grippy ergonomic
handles. Plunge models have rust-proof brass bushings on the
plunge mechanism, through-the-column dust collection, and a
five-position adjustable stop. Street prices range from $159
for a 13/4-horsepower fixed-base to $249 for a 21/4-horsepower
kit with both plunge and fixed bases.
Contact: DeWalt, Baltimore, Md., 800/433-9258,
http://www.dewalt.com.
Speakers for the Great
Outdoors
Homeowners wanting to hear their tunes or talk radio outside
can now choose corrosion- and weather-resistant outdoor
speakers from M&S. The speakers feature a 51/4-inch
two-way woofer and a titanium dome tweeter and are said to be
ideal for outdoor entertainment areas. Gold-plated binding
posts, aluminum mounting brackets, and brass hardware help them
look good and last a long time in the great outdoors. Each
speaker measures 71/4 inches wide, 95/8 inches tall, and 61/2
inches deep and can handle 70 watts. A pair retails for
$239.
Contact: M&S Systems, Dallas, Texas;
800/877-6631, http://www.mssystems.com.
Hot Product
Scalding hot water in the tub or shower is serious business.
The HydroGuard HT115 monitors water temperature to
prevent burns. When the device senses water temperatures above
115°, it reduces flow to a trickle (1/4 gpm), continuing
normal flow within seconds after safe temperatures return. The
all-brass device screws on to an existing shower arm, works
with both fixed and hand-held showerheads, and costs only
$25.
Contact: Powers, Skokie, Ill.; 800/669-5430,
http://www.powerscontrols.com.
Got a Tool Vice?
If you've held out for the ultimate in multitools, the new
Vise-Grip Toolbox might be the one you've been waiting
for. A small but useful set of Vise-Grips, with wire cutters on
the business end, replaces the typical needle-nose pliers. The
other end of the tool includes two locking knife blades and a
bit holder that accepts standard 1/4-inch hex-shaped sockets
and driver bits. Although it doesn't have a strap or flap, the
included sheath keeps the tool secure and allows quick
one-handed draws. Warning: If you open both blades and the bit
holder at the same time, you'll need a screwdriver to unlock
them again. It's likely to happen when you show a friend -- I
know. The Toolbox sells for about $30.
Contact: American Tool Companies, Wilmington, Ohio;
800/866-5740, http://www.visegrip.com.
This Is a Stickup
Hot-melt glue is good for temporarily securing trim before
pneumatic fastening because it sets quickly and might keep you
from blowing a brad through your finger. But carpenters need to
move fast, corded glue gun and all. The G200K Portasol
is a professional-duty, butane-powered hot-melt glue gun that,
according to the manufacturer, will work for five hours on a
fill-up from readily available cigarette lightertype
butane. An on-board piezo igniter starts the fire, and a small
window confirms that the gun is heating; it's ready to shoot
glue in about four minutes. A foldout stand on the handle keeps
it upright. The G200K includes a blow-molded case and sells for
$160.
Contact: Cooper Tools, Apex, N.C.; 919/362-1670,
http://www.coopertools.com.
Rock On
In recognition that a radio is as much a necessity on the job
as a cup of morning coffee, the Job Site Radio is
designed to keep the crew rocking. According to the maker, the
digital-tuning radio can take an 8-foot dive onto concrete and
live to broadcast the tale. Twenty station presets introduce
single-digit ease to the favorite-station squabble, and the
omni-directional, flexible rubber antenna is supposed to
deliver clear reception even in remote areas. A clever
pass-through plug keeps the radio from tying up an outlet or
uses your 12- to 18-volt Milwaukee battery pack for power. With
a national weather band, digital clock, 12-volt auxiliary power
port, and input jack for a portable CD or MP-3 player included,
my only question is where's the on-board charger to juice up
your Milwaukee battery packs? The JSR has a street price of
about $100.
Contact: Milwaukee Electric Tool Corp., Brookfield,
Wisc.; 800/414-6527, http://www.mil-electric-tool.com.
Cure for Common Rot
Frequently, repairing even badly rotted wood is possible and
less expensive than replacement, according to the maker of a
two-part Advanced Repair elastomeric epoxy. According to
the maker, the epoxy can rebuild rotten windowsills, columns,
structural elements, and even wood gutters and won't slump or
sag when applied to vertical or overhead surfaces. It won't
shrink as it cures and can be painted or stained to match
existing materials. Mixed epoxy has a 30-minute open time;
unmixed material will keep for up to one year. A starter kit,
including a double-barrel caulk gun, 12 ounces of primer, and
16.8 ounces of two-part epoxy, costs $135, shipping not
included.
Contact: Advanced Repair Technology, Cherry Valley,
N.Y.; 607/264-9040, http://www.advancedrepair.com.
Pencil-Free
When did tape measures start looking like SUVs?" one of my
coworkers asked when shown the Next unleaded measuring
tape. A tiny marking wheel, similar to a glass cutter,
mounted on the housing, is said to leave a mark on almost any
surface. A pointer on the tape housing, aligned with the
marking wheel, indicates the chosen dimension. The tape comes
in 16-, 25-, and 30-foot lengths and features a rubber covering
for a good grip and impact resistance. I was able to get an
8-foot standout, and several uncontrolled retractions from 20
feet failed to do any damage to the spring or blade. But claims
by the maker that it's easier to use than a traditional tape
and pencil seem dubious. A 25-foot tape runs about $20.
Contact: Levelution, Hailey, Idaho; 888/475-3835,
http://www.levelution.com.
High and Dry
The space under a raised deck is frequently wasted because it
offers little or no protection from rain or melting snow.
Dry Space, a PVC rain diverter, fits between the deck
joists and catches runoff, channeling it to the outside edge of
the deck or a gutter system. F-brackets mounted on the side of
the joists secure the panels without restricting seasonal
movement. The system is now compatible with 16- and 24-inch
on-center spacing, and the panels and accessories are
manufactured in 12- and 16-foot lengths. The system is designed
to allow a slight pitch to get the water moving in the right
direction. Manufactured in an unobtrusive off white, it runs
$3.20 per square foot.
Contact: Crane Products, Columbus, Ohio; 800/200-6121,
http://www.dryspace.cc.
One Less Headache
If your wobbly cab protector is giving you a migraine,
consider a sturdy new one that promises to alleviate your pain.
Unlike cab protectors that bolt through the top of the bed
rails only, the Headache Rack is fastened to the top and
inside edge of the bed with L-shaped angle brackets. This
double-bolting results in a stronger and longer-lasting design,
and rubber pads protect the truck's finish under the mounts.
The Headache Rack is made of 2-inch, 16-gauge chrome-plated
steel tubing with stainless-steel louvers. Options include a
black powder-coat finish and a sliding louver panel in the
rack's center to accommodate sliding rear windows. Headache
prevention costs $375 for the chrome, fixed-louver model.
Contact: Go Industries, Richardson, Texas;
800/527-4345, http://www.goindustries.com.
Breathe Easier
Metal roofing is increasingly popular but a little tricky to
vent through the ridge. Profile Vent is similar to other
rolled fibrous ridge vents, but it's available in 39 different
profiles to match common standing-seam and screw-down metal
roofing. The vent is sold in 20-, 50-, and 100-foot rolls and
features self-adhesive glue spots to keep it in position while
you fasten the ridge cap. Five-hundred-foot master rolls with
an automatic dispenser are also available for installers who
fabricate their own roofing. Prices run about $1.90 per
foot.
Contact: Ventco, Glenside, Pa.; 800/300-9515,
http://www.profilevent.com.
Swell Well
For an alternative to ugly galvanized window wells, consider
these easily installed Window Well Pictures. According
to the maker, the flexible and waterproof images dress up the
plain zinc finish of a standard window well by replacing it
with one of four attractive landscape scenes. Development of
other scenes and landscapes continues. The high-resolution
images are printed with UV-resistant inks and fit wells up to 4
feet deep and 12 feet in circumference. Prices range from $40
to $60 each.
Contact: Window Well Pictures, Boise, Idaho;
888/226-7658,
http://www.windowwellpictures.com
