The AEG HBSE 75 S and the Ryobi
BE-321 are among the new generation
of small, streamlined belt sanders.
Their sleek appearance is characterized
by an in-line motor that centers
the weight of the tool over the belt
and lets you sand flush to corner
edges. They have a low center of gravity
so they are stable, move easily
across the work, and are comfortable
to hold. Both the AEG and the Ryobi
sanders operate at variable speeds,
which gives you added control over
the sanding surface. Both offer a sanding
frame that clips to the bottom of
the sander to provide stability and
precise depth control. And both easily
convert into portable benchtop
sanders with a few
