by Patrick McCombe
After
years of looking, I had just about concluded that high-quality
wall caps didn’t exist when I came across Seiho’s
Aluminum and Stainless Steel Dryer Vents. Good-looking and
well-made, they come in several styles, with and without
dampers. Prices start at about $40. Seiho also makes stylish,
high-quality hvac diffusers and grills. Seiho,
800/248-0030,
www.seiho.com.
Running
low-voltage landscape lighting is easier with the direct-burial
Pro Series LV Junction. Made from polycarbonate with
stainless-steel contacts, the hub has a silicone-filled
junction block for the line side and six O-ring sealed
connections for fixtures. It costs $140. Companion 16-gauge
25-foot cables cost $20 each. Kichler,
866/558-5706,
www.landscapelighting.com.
Packable
Primer.
Conscientious carpenters now have an
easy and convenient way to field-prime vulnerable end grain.
End Cuts water-based primer — which comes in a plastic
bottle with a sponge applicator — is the perfect size for
your toolbelt and won’t spill. It’s suitable for
interior and exterior use; a similar product with a clear
finish is also available. A 4-ounce bottle of End Cuts costs
$10. Ze-Vo Products, 508/879-3151,
www.ze-vo.com.
One of the major beefs contractors and
homeowners have with solar water-heating systems is that they
require a conventional water heater for backup. However, the
EnerWorks uses a conventional electric water heater for both
storage and backup, making a second tank unnecessary.
Single-collector systems — excluding installation —
start at about $3,300. EnerWorks,
877/268-6502, www.enerworks.com.
For
professional-quality landscape lighting, skip the home-center
products and get a Dual Output Multi-Tap Transformer from Sea
Gull Lighting. Housed in a powder-coated metal cabinet with
plenty of room for connections, it’s thermally protected
and dimmable, and comes in 600- and 1,000-watt versions with
one boost tap to compensate for the voltage drop associated
with longer runs. Model 94065-12 (1,000 watts) costs about
$500. Sea Gull Lighting, 800/347-5483,
www.seagulllighting.com.
Safer Stripper.
Although stripping
paint is never going to be fun, it can at least be less
dangerous. Jasco Green Strip is biodegradable, low-odor, and
safe to use indoors, according to the manufacturer. Free from
methylene chloride, it clings to vertical surfaces and removes
both oil and latex paints. The company says the softened paint
and stripper is ready for removal in about an hour. A 22-ounce
spray bottle sells for $12. Homax Products,
800/729-9029,
www.homaxproducts.com.
Available in seven
widths from 2 to 4 feet, Quick Drain is made entirely from 316
stainless steel and is only 21/4 inches tall with the trap. The
maker claims it works with any size or thickness of tile and
can be installed anywhere in the shower floor. Prices start at
$400. Quick Drain USA, 970/389-6582,
www.quickdrainusa.com.
When
conventional lumber can’t span the distance on your
outdoor project, give Wolmanized Parallam PSL (parallel strand
lumber) a try. This pressure-treated product is rated for
unprotected exterior applications and comes in headers, beams,
and posts that can be painted or stained with oil-based
finishes. The maker says it resists insects and decay better
than conventional treated lumber. The company did not provide
pricing. Weyerhaeuser Co., 888/453-8358,
www.ilevel.com.
