by Patrick
McCombe
Full-Head Cordless Framer.
Paslode's cordless framing nailers have always been popular
with professionals. However, some tasks require full-head
nails, which means that clipped-head framers like Paslode's
need proprietary nails with an offset head; these special nails
can be tough to find and can be a problem with picky
inspectors. A new full-head gas-powered framing nailer from
Powers can help. Like the Paslode, the Trak-It W3-21FRH
contains a linear-combustion engine powered by a disposable gas
cylinder; unlike the Paslode, it accepts shear-wall-friendly
22-degree Hitachi-style plastic-collated nails from 23/8 to
31/4 inches. It sells for $399. Powers, 800/524-3244,
www.powers.com
Sheathing Specialist.
With a head
that's 30 percent larger than that of conventional sheathing
nails and with 20 percent more shear strength, Bostitch's new
Hurriquake Collated Nail weathers storms better than other
collated nails, says the company. An update of the Sheather
Plus, the new nail lacks the older version's purple coating
because lab tests showed better performance in high-wind and
seismic events without it. Other upgrades include stiffer
plastic collation, an aggressive ringed shank, and deformation
under the head (to prevent racking). Using the new nail on a
2,000-square-foot house costs about $15 more than using
conventional nails, estimates Bostitch. Hurriquake nails come
in .113- and .131-inch versions — in 21-degree collation
only — to fit most popular full-head nailers. Bostitch,
800/556-6696, www.bostitch.com
Worry-Free Collated Fasteners.
By
now, quality-conscious contractors know that stainless-steel
fasteners are the best choice for exterior work, especially for
the new formulations of pressure-treated lumber. Swan Secure
Products offers stainless collated nails and staples for just
about any application, including Stainless-Steel Metal
Connector Nails in 20- and 31-degree collations and
.120-inch-diameter stainless-steel Spiral Shank and Ring-Shank
Nails; the latter, I have found, resist bending and penetrate
dense materials better than thinner — but more widely
available — stainless siding nails do. The company also
makes stainless finish nails, metal connectors, lag screws, and
carriage bolts. See its Web site for prices. Swan Secure
Products, 800/966-2801, www.swansecure.com
Skylights
Thin Is In.
Designed for easy
installation in roofs with 16-inch-o.c. framing, Insula-Dome
14-inch-wide skylights come in six standard sizes from 22
inches to 8 feet long. These narrow units speed installation by
eliminating any need for extensive reframing and the associated
drywall or plaster repair. Available for sloped and flat roofs,
all units feature energy-efficient glazing, double-seal EDPM
gaskets, and built-in condensation channels. Customers can
choose from one-piece soldered copper flashing or aluminum step
flashing. Without options, a 14x46-inch fixed skylight has a
"trade list" price of $150 ($308 for the same-size vented
model) plus $53 for the flashing kit. Insula-Dome,
800/551-4786, www.insula-dome.com
Premium-Grade Shade.
Skylights are
a great way to add a little ventilation or brightness to a
living space, but blinding light from an overhead opening can
be a real nuisance to folks trying to watch TV or to sleep
— or to homeowners trying to keep summer temperatures
below boiling. Thanks to layers of ceramic film, the SageGlass
found in Velux skylights changes from clear to deeply tinted
with just the flip of a switch. Not surprisingly, the
cutting-edge technology doesn't come cheap; expect to pay
$1,800 for a VS104 with SageGlass compared with $644 for the
same unit without the feature. Velux, 800/283-2831,
www.veluxusa.com
Step-Saver.
Offered in nine
standard sizes and featuring a one-piece curb, Wasco's
E-Class SkyWindow boasts the largest glass area
available and installs faster than any other major brand of
skylight, says the company. Key to its speedy installation is a
one-piece flexible flashing that makes sealants and step
flashing unnecessary. List prices range from $172 for a
22x22-inch fixed window with clear glass to $945 for a
461/2x451/2-inch motorized venting unit. Wasco, 800/388-0293,
www.skylighting.biz
Instantaneous Water Heaters
Safety in Mind.
Like many other
manufacturers, Rheem has installed several safety features on
its tankless water heaters that aren't commonly found on
conventional heaters. Case in point: A safety film covering the
heat exchanger in the RTG-74 shuts the unit down if things get
too hot. Should the opposite problem occur — a
heating-system failure or an unusual freeze in a typically warm
climate — a built-in heater protects internal components
down to -30°F. The RTG-74 has an oxygen-depletion safety
device, too, which monitors oxygen, carbon monoxide, and carbon
dioxide and shuts off the gas supply if there's a problem. I
found the RTG-74 on the Web for about $900. Rheem,
800/432-8373, www.rheem.com
Spot Hot.
It can take forever for
hot water to get to a half-bath or sink located far from the
water tank. But there's an easy fix: an electric point-of-use
heater like Stiebel-Eltron's DHC. Electric point-of-use models
don't need a flue, and since they make hot water right where
it's needed, there's no waiting or wasted water, either. The
DHC comes in eight models from 3,000 to 9,600 watts; all units
feature scald-guard thermostats and compact cabinets. According
to the manufacturer, the DHC uses 50 percent less energy than a
comparable tank-type electric water heater. Prices start at
$170 to $200. Stiebel-Eltron, 800/582-8423,
www.stiebel-eltron-usa.com
Steady as She Goes.
Modulating
burners like those found in Bradford White's EverHot tankless
gas water heaters save fuel and provide a more consistent water
temperature than nonmodulating burners do. Available in two
indoor and two outdoor models, the EverHot units can deliver
about 4 gallons per minute at a 77°F temperature rise and
sport an easy-to-use digital control panel for temperature
adjustment. I found it on the Web for about $1,300. Bradford
White, 800/523-2931, www.bradfordwhite.com
