StakWel Egress System
The StackWel Egress Window Well system uses modular units that stack together to accommodate virtually any foundation depth. Recently redesigned to accommodate window openings up to 54 inches wide, the system is constructed of corrosion-resistant high-density polyethylene. StakWel is impervious to soil and moisture conditions, and will not rust, rot, or discolor, the maker says. Use it with utility or egress windows. Bilco | 800.854.9724 | bilco.com
2015 Ford Transit
The 2015 Ford Transit maximizes the usefulness of a full-size van. Engineered to Ford's strict standards for commercial truck durability, three van models have cargo volumes ranging from 246.7 cubic feet to 487.3 and carries payloads up to 4,650 pounds. Available features include wide-swing cargo doors, GPS and jobsite productivity tools, and a rear-view camera and trailer hitch assist. Ford | ford.com
HydroBan Shower System
The expanded Hydro Ban product line gives contractors a one-stop shop for everything needed to install detailed custom showers. Components for Hydro Ban Shower Systems include pre-sloped shower pans, backerboard, sheet membrane, benches, shelves, and niches. The pre-formed elements are constructed of lightweight high-density polystyrene and feature a code-approved waterproof coating ready to accept tile. The system also includes a variety of linear and flange drain designs to complement faucets, showers, and other plumbing fixtures. Laticrete | 800.243.4788 | laticrete.com
Bellawood Oil-Look Matte Flooring
Bellawood's product line now includes prefinished oil-look matte styles, including natural hickory and American walnut (shown). The matte finish line features a proprietary topcoat that helps boost scratch, scuff, and stain resistance, making it ideal for high-traffic areas, and homes with children or pets. The highly durable finish is backed by a 100-year transferrable wararnty. Lumber Liquidators | 800.427.3966 | lumberliquidators.com
3-Panel Shaker Interior Door
Offering a clean and timeless aesthetic, Masonite introduces its 3 Panel Share interior door. Modeled after a wood stile-and-rail door, the 3 Panel Door offers the durability of molded construction, and the classic look of a wood door. True to the aesthetic, Masonite has incorporated the addition of witness lines into the door's tooling to mimic the lines where stiles and rails would be joined in a wood door. The 3 Panel Door is available in 6-8 and 7-0 heights as a standard door or bi-fold. Masonite | masonite.com
NoviShake and NoviStone
Naturally detailed cedar shakes and dry stacked stone are among the polymer exterior siding products highlighted by Novik in their inaugural Remodeling Show visit. NoviShake RS8 8-foot cedar shake panels replicate the appearance of real wood, while the specially formulated polymer is engineered to withstand extreme temperatures. Available in two dozen shades, the through-color panels never need to be painted and are lightweight for efficient installation. The siding is nicely accented by NoviStone DS, a virtually maintenance-free version of dry stacked stone that resists warping, expansion, contraction, and cracking. Novik | 888.847.8057 | novik.com
Square Kitchen Island Posts
Square turned posts offer contemporary and transitional style to woodworking projects. Kitchen island posts are unfinished and available in more than 18 species. Osborne's millwork services include custom notching, receptacles for electrical application, additional sanding, splitting, and more, helping to ensure items arrive ready for use without additional lead time. Osborn | 800.849.8876 | osbornewood.com
Ditra-Heat Floor Warming
Ditra-Heat aims to tackle the issues of floor warming-induced expansion and contraction in floor assemblies by combining floor warming and uncoupling in a single layer. The product's heating cables are snapped into place on top of the uncoupling mat without clips or fasteners, giving the installer flexibility in where the cables are placed so every project is customized. Because they're held in place with the Ditra-Heat mat, installers don't need to use self-leveling compounds to encapsulate the heating cables. This expedites installation by eliminating the waiting time when the compound would set, and tile installation can begin immediately. Ditra-Heat is available in rolls and sheets, and cables are available for 120V or 240V circuits. Schluter Systems | 800.472.4588 | schlutersystems.com
Everlast Basement Wall Panels
The EverLast Wall System helps make finished basements even more comfortable thanks to SilverGlo insulation. An added radiant barrier on the back of the wall system panels bumps the insulation to 2 1/2 inches thick with an R-14. The gray foam is impregnated with graphite to reflect heat, helping the panels resist conductive heat flow. In addition to its insulating properties, the EverLast Wall System resists mold, termites, and fire. Total Basement Finishing | 877.818.1482 | totalbasementfinishing.com
Cellular PVC Sill Molding
A correctly profiled, ready-to-install cellular PVC sill molding is now available to replace wooden double-hung window sills. The one-piece molding saves on labor by incorporating both the sill and sill nose otherwise assembled on-site. The full 1 1/4-inch profile fits standard double-hung applications and comes factory-sanded and primed in 18-foot lengths. Versatex | 724.857.1111 | versatex.com
More Product Coverage from the 2014 Remodeling Show | Deck Expo | JLC Live Event:
6 Companies You've Never Seen at the Remodeling Show - Until Now
9 New Products from the R|D|J Show Floor
