9 New Products From the R|D|J Show Floor
Catching up after the Remodeling Show? Here's what you may have missed.
If you found yourself in the unfortunate position of missing the 2014 Remodeling Show | Deck Expo | JLC Live event in Baltimore last week, fear not! Our editors were on hand to scour the show floor and bring some new product highlights. Check out these new products for your next remodel or deck project.
Andersen Windows with Verilock
Adding the option of Honeywell Verilock sensors lets homeowners tie E-Series windows into their home security system. The sensors are built into the windows’ locks and require no visible wiring to communicate locked, unlocked, open, or closed, status with a home security system. Whereas other window and door sensors can void product warranties, the Verilock sensors are embedded at the factory, keeping the warranty intact. Besides home security, window and door sensors can help homeowners improve their energy efficiency, identifying windows that need to be closed or locked to keep conditioned air in the home where it belongs. Andersen Windows | 888.888.7020 | andersenwindows.com
Dexerdry Deck Waterproofing
Adding a rubber mallet to your toolbox is all you need to install Dexerdry as part of your next deck project. The above floor joist flange act as spacers for deck boards while waterproofing the deck and providing dry, useable space underneath. Designed to withstand the element, Dexerdry is low-maintenance and can withstand 3000 psi powerwashing. Dexerdry | 732.551.9969 | dexerdry.com
Exteria Building Products
Combining decades of experience in cedar replicas and polypropylene cladding, Exteria’s shake, shingle, and masonry panel options give exterior designers and their clients a variety of color and texture combinations. EZ Lock panels install in 25% less time than similar products, and offer virtually maintenance-free cladding. The maker’s Responsibility to Realism initiative helps ensure that products including Stacked Stone and Rough-Sawn Cedar have a truly authentic look. Exteria Building Products | 877.398.3742 | exteriabp.com
NyloBoard NyloPorch Porch Flooring
NyloPorch is the latest introduction from NyloBoard, and is made from the same composite material as the original decking material – 100% recycled carpet fiber. The tongue-and-groove porch boards contain no wood or PVC, and resist moisture, mold, mildew, and termites. Available in 3- and 5-inch widths and the same five colors as NyloDeck, NyloPorch is rated for uniform live load of 100 pounds per square foot with support framing spaced at up to 24 inches. The material is backed by a 25-year fade and stain warranty, and a 25-year limited residential warranty. NyloBoard | 877.695.6909 | nyloboard.com
Panda Windows
If a wide-span door is called for on your next high-end project, consider the flexibility of Panda multi-panel sliding and folding doors. Available in a variety of heights and widths.Folding door styles allow designers to specify certain panels as in-swing doors for easy passage without opening the entire door. Sliding doors have the benefit of a flush track for a smooth, no-threshold finish. Panda Windows | 702.643.5700 | panda-windows.com
Quick Door Hanger
Set aside the shims on your next door installation project. Quick Door Hanger brackets feature alignment tabs and reference notches that allow installers to easily line up doors along level and plumb lines without nail holes or shims. The brackets also feature malleable tabs in case the door needs to be adjusted front to back in the rough opening. Door casing and trim will hide the brackets upon finishing, which takes place up to five times faster than with standard door installation. Quick Door Hanger | thequickdoorhanger.com
Royal Building Products Celect Exteriors
Celect cellular PVC siding and trim are lightweight and flexible, allowing for 50% faster installation time than other materials, the maker says. The dimensionally stable material comes in 18 colors and is designed to resist the elements while mimicking the look and feel of wood, thanks to the deep grain texutre. On installation, Celect siding uses an interlocking joint system rather than being butted together, yielding a smoother aesthetic. Complementary Celect trim gives the benefits of sanded lumber, and comes ready to install and fully paintable. Royal Building Products | 855.523.5328 | celect.royalbuildingproducts.com
Skilsaw Sidewinder
Inaugurating its new brand identity, Skilsaw introduces its new pro Sidewinder circular saw with all-magnesium guards, foot, and motor housing. The only all-magnesium saw available, the metal offers strength and durability for the jobsite, while also helping the motor dissipate heat, ultimately extending the life of the tool. The 15-amp Dual-Field Motor uses a unique copper winding pattern with increased surface area that keeps the motor cooler while providing improved power and torque over previous models. Skilsaw | skilsaw.com
TrakBelt 360
The creator of this clever work belt, Chris Landano, serves as a New York City firefighter and forensic photographer. When his photography belt got him caught in a tight, dangerous spot in the midst of a building collapse, a light bulb went on. He developed a belt that rotates, allowing the wearer to narrow the bulky profile of a work belt by rotating tools and pouches out of the way. For Landano, this lets him slip in and out of tight spaces without his photography gear hanging him up. On a jobsite, the rotating belt lets wearers find their tools easily, and slide them out of the way to keep from marring drywall or other finished work. TrakBelt 360 | trakbelt360.com
More Product Coverage from the 2014 Remodeling Show | Deck Expo | JLC Live Event:
10 New Products Coming to the Remodeling Show
6 Companies You’ve Never Seen at the Remodeling show – Until Now
Lauren Hunter
