Caulks, Sealants, and Adhesives Products
Pecora. The first of its kind, 890FTS Field-Tintable Silicone sealant allows contractors to tint silicone in the field, expanding their color palette without special orders or cost concerns of over- or under-ordering. The product’s Quick Mix technology requires only three minutes of mixing time. The silicone will not stain porous surfaces like granite and marble, offers superior adhesion to most substrates without primer, and does not experience residue rundown, the maker says. 800.355.8817. www.pecora.com.
OSI. The OSI Green Series line of caulks, sealants, and adhesives combines environmentally friendly formulations that meet VOC regulations or green building standards with high performance and long-lasting quality. The series includes H2U acrylic urethane sealant, SA-167 siliconized acrylic latex caulk, SW-325 shear & drywall adhesive, SF-550 high-performance deck and subfloor adhesive, PF-33 Quick Set Pro-Foam II acrylic urethane sealant, SC-175 draft and acoustical sound sealant, and FlameSeal fire, smoke, and draft stop sealant. 800.999.8920. www.osiproseries.com.
Liquid Nails. The company’s first cartridge-based latex construction adhesive, Ultra Quik Grip, can be used for a range of construction applications, including concrete, brick, ceramic tile, lumber, dry-wall, and cork. The product is formulated to provide a strong initial tack and a high bond strength that eliminates the need for bracing and fasteners, the maker says. The VOC-compliant adhesive is non-flammable and virtually odorless, and can be cleaned with soap and water. 800.634.0015. www.liquidnails.com. Franklin International. VOC-compliant Titebond 821 Premium urethane wood flooring adhesive offers a bond strength of 220 psi and a powerful initial grab. The adhesive instantly grips solid wood flooring planks and holds them in place for easier and faster installation, the maker claims. The water-free, non-slump formula allows the option of wet-laying flooring materials and further speeding up installation by eliminating the need to wait for adhesive to flash. 800.347.4583. www.titebond.com. For more product information, visit ebuild, Hanley Wood’s interactive product catalog, at remodelingmagazine.com or www.ebuild.com.
