DriTac. The 7700 Easy Clean green hybrid urethane wood flooring adhesive incorporates a range of adhesive technologies to offer a product that cleans up easily when wet or dry. The zero-VOC, zero-solvent adhesive helps contribute to LEED point qualification and is ideal for installing bamboo, exotic woods, multi-ply engineered plank, solid wood plank, acrylic-impregnated wood, and plain-back parquet and plywood. Available in 1- and 4-gallon pails, DriTac 7700 Easy Clean is suitable for above-, on-, or below-grade installations, is freeze-thaw stable and non-slumping, and remains elastic to allow for normal wood floor expansion and contraction. 800.394.9310. www.dritac.com.
Waterproof Gypsum Backerboard
Expansive Glass Wall
Interior Fire-Rated Plywood
