Water Source Geothermal Heat Pump
Bosch.com
The Bosch RP Split is an Energy Star–certified water-to-air geothermal heat pump available in 2- to 5-ton capacities. The unit’s two-stage scroll compressor adjusts output to demand for optimal efficiency while ½-inch closed-cell foam insulation combined with a floating compressor base allows for quieter operation. A low-profile, compact footprint fits in tight retrofit spaces. The model using R-454B refrigerant complies with criteria for lower global warming potential. The heat pump can be paired with the Bosch BV20 variable-speed air handler. bosch-homecomfort.com
