Double-Sided Containment Tape
Designed for remodel and abatement work, this Shurtape product uses different specialized adhesives on each side for a secure seal
Help reduce labor and materials cost when sealing off spaces for restoration, remodeling, and abatement projects. Shurtape’s DS 154 Double-sided Containment Tape features the same painter’s tape adhesive used on popular FrogTape on the wall side, while the opposite side uses a specially formulated aggressive adhesive to securely hold poly sheeting, tarps, and other protective coverings in both wet and dry environment. The two-in-one design results in full-surface contact and an air-tight hold even in negative-pressure containments. DS 154 offers a 21-day clean removal without damage or residue. Check with dealers for pricing. shurtape.com
