Residential
Hand-Held Vac Made for Jobsite Cleanup
The Bosch GAS18V-02N 18V features two-state rotational airflow technology and a 61-cubic-inch capacity.
The Bosch GAS18V-02N 18V Cordless Handheld Vacuum Cleaner.
Bosch
Bosch’s newest hand-held vacuum, the Bosch GAS18V-02N 18V Cordless Hand-held Vacuum Cleaner, is designed to serve as a lightweight jobsite cleaning solution. It weighs 2.9 pounds without its battery, provides up to 21.2 CFM of airflow and up to seven minutes of runtime per battery amp hour (Ah), and holds up to 61 cubic inches of debris.
The vacuum uses two-stage rotational airflow technology to keep the washable HEPA filter clog free for longer. The first airflow stage captures 90% of jobsite debris, while the second stage catches finer particles. It is easy to empty, and users may check the fill level through its transparent shell at any time.
Five attachments are included: extension pipes and a floor nozzle, which allow the hand-held vacuum to be used as an upright, and a crevice nozzle and short hose for hard-to-reach areas and tight corners.
The GAS18V-02N 18V will be available starting in the summer of 2018. It is compatible with all Bosch 18V batteries, which are sold separately. boschtools.com
This article originally appeared in Builder.
Mary Salmonsen
Mary Salmonsen is a former associate editor for Zonda and a graduate of the S.I. Newhouse School of Public Communications at Syracuse University.
