Collaborative Rainscreen and Cladding
A collaboration between Kebony and Grad Concept USA, Grad for Kebony is a combination rainscreen and cladding system using aluminum Grad Mini Rails and Kebony Grad Cladding. First, the rails are fastened to the sheathing, creating what will be an air space behind the cladding. Then Kebony modified-wood boards, which are grooved on the back to articulate with clips that have been factory-mounted on the rails, snap into place. The rails come in two versions: One results in a narrow gap between cladding boards for a nickel-gap look, and the other creates a wider gap for more of a shiplap appearance. Both can be installed vertically and horizontally. us.kebony.com
