Fire Prevention: Fomo Products Handi-Foam Ignition Barrier
Handi-Foam Ignition Barrier helps ensure code-compliant spray polyurethane foam installations. The latex-based material can be sprayed to coat Handi-Foam E84 Class 1 spray foam. The material creates a carbon layer that removes fuel from fires, preventing or delaying ignition. Handi-Foam ignition barrier is nontoxic, non-carcinogenic, and low-VOC, and requires a lower mil thickness than other coatings. Fomo Products | 800.321.5585 | fomo.com
Lauren Hunter
