Decra Roofing Systems.
Made of steel, Villa Tile barrel-profile roof tile is coated with stone to achieve the look of old-world Italian tile. The tiles can be installed directly to the roof deck or over battens, and they come in five standard colors. Tiles interlock, are lightweight, and will not crack, burn, curl, split, or rot, the maker says. 877.463.3272. www.decra.com.
Hitachi Power Tools.
Upgraded features of the NV45AE 1 3 / 4 -inch coil roofing nailer include lower recoil and a faster firing speed. A quick-firing two-valve cylinder carries over from the popular NV45AB2 model, and a pneumatic nail-feed mechanism powers both the nail advance and return for consistent operation. A 30% faster bump-firing speed and optimized recoil help increase productivity. All-aluminum construction offers durability. 800.829.4752. www.hitachipowertools.com.
Duration shingles with SureNail Technology have a wider reinforced nailing area and an easily recognized nailing strip that increases installation accuracy and boosts productivity. Interaction between the Tru-Bond sealant and the SureNail nailing strip provides additional bonding strength that gives the shingles high wind ratings: 130 mph on Duration Premium shingles and 110 mph on Duration shingles. 800.438.7465. www.owenscorning.com.
MFM Building Products.
Ideal for low-slope/low-pitch roofs, versatile Peel & Seal also solves waterproofing problems around chimneys, vents, ducts, skylight windows, and other irregular features. Composed of a patented laminate of aluminized foil, high-density polymer film, and a thick layer of rubberized asphalt, Peel & Seal is flexible, self-sealing, energy efficient, and will not crack or dry out from exposure, the maker says. Available in almond, granite gray, aluminum, or white. 740.622.2645. www.mfmbp.com.
For more product information, visit ebuild.com, Hanley Wood's interactive product catalog.
