Smooth Panel Siding
LP Building Solutions has introduced LP SmartSide Smooth-Finish Panel Siding. The panel siding has a no-groove square edge for easier use in channel applications, according to the manufacturer, and is designed to hold up against extreme weather conditions, including moisture, freeze/thaw cycles, and wind gusts up to 200 mph. The panels are treated with the company’s SmartGuard process for protection against fungal decay and termites and are preprimed for simple paint adhesion. Contact a local distributor for a quote. lpcorp.com
