Grab Hold: Loctite Power Grab Clear Construction Adhesive
With nearly nine times the tack of competitive products, according to the maker, Power Grab Clear Construction Adhesive dries clear for a smooth finish. The adhesive helps hold projects in place without the need for nailing or bracing, and can be repositioned for up to 15 minutes. Bonds to wood, drywall, concrete, and rigid plastic, and is ideal for a range of projects from installing drywall to repairing retaining walls. Loctite | 800.624.7767 | loctiteproducts.com
Lauren Hunter
