New + Notable: Railing Systems, Hardwood Floors, Cabinetry and More
WIRED IN
Low maintenance and innovative design come together in CableRail’s aluminum railing frame systems for interior or exterior applications. The pre-engineered component systems incorporate heavy-gauge 6036-T6 aluminum extrusions that can be quickly and easily cut and assembled on site. No welding, grinding, or special finishing is necessary. Add recessed high-intensity lights for dramatic nighttime effects and increased visibility. Eight standard colors and more than 200 custom colors offer abundant design opportunities, as well as strong color retention, impact resistance, and weatherability. CableRail by Feeny. 800.888.2418. www.cablerail.com.
LIGHT TABLE
The elegant but modern line of Jonathan David Furniture Vanities from Debra May Himes now includes the “Grace” style. The wall-mounted half-circle vanity sits on a hand-forged wrought iron pedestal, topped with a semiprecious onyx surface polished to a high gloss. Underneath, set-in lighting creates a soft glow. The Grace is available in various onyx choices, each of which will be one-of-a-kind with varying patterns and coloration. The vanity measures 42 inches wide and 24 inches deep. Debra May Himes. 480.921.0900. www.dmhdesign.com.
RECLAIMED RARITIES
When forests were cleared in the late 1800s, logs floated downstream to mills for processing; some logs never arrived. Goodwin Heart Pine recovers these antique pine and cypress logs from Florida’s Suwannee River, slowly drying and milling them into stunning flooring, stair parts, moldings, cabinetry, and more. “Select grain” pieces feature vertical and arching grain patterns, while “vertical grain” pinstripes result from a more intricate sawing method. “Curly grain” is the rarest find, occurring in one out of every 300 to 400 logs. When originally harvested, the antique heart pine logs were 200 to 500 years old and the cypress logs were aged 900 to 1,700 years. Goodwin Heart Pine. 800.336.3118. www.heartpine.com.
INDUSTRIAL DECO
Inspired by the industrial style of the 1930s, the Zephyr line of decorative cabinet hardware includes knobs and pulls in an assortment of finishes and sizes. The sleek, contoured lines are designed to manage the delicate balance between form and function. Three finish options include satin nickel, oil-rubbed bronze highlighted, and Venetian bronze. The line includes 1- and 1¼-inch knobs, and 3-inch, 96mm (3.78-inch), and 128mm (5.04-inch) pulls. Hickory Hardware. 800.235.9484. www.hickoryhardware.com.
