New Products for the High-end Remodeling Market
High Lighting
Deliver natural light to almost any space through a flexible fiber optic cable with the Fiber Optic Skylight. Smaller in diameter than a pencil, up to 60 feet of the fiber optic cable can be routed through walls and floors and brought to the area where light is needed. The skylight is comprised of an exterior mounted panel with 64 computer-controlled lenses inside that rotate and track the sun throughout the day. The lenses focus the sunlight onto the optical fibers. A variety of available luminaries then diffuse the light inside the home. HUVCO. 800.832.6116. www.huvco.com.
Chill Out
New to North America, the Independence Series includes 18-, 30-, and 36-inch-wide modular refrigerators and freezers, and a 24-inch-wide wine chiller. MasterCool controls in a backlit display let users adjust temperature and humidity for each compartment, while the SuperCool function helps quickly chill new groceries. FullView drawers and ClearView lighting make items easy to see and reach. The line also features Remote­Vision wireless technology, a virtual link that will prompt Miele’s service center to contact the homeowner should the unit require service. Miele. 800.843.7231. www.miele.com.
On Track
Use modular base block, spool, and column choices to create customized decorative columns with ColumnTrack. Each half-round segment is notched in the back, allowing it to rest on a glueable wood spline that is shipped with each column. With all the pieces in place, ColumnTrack columns look as though they were hand-turned from a single length of wood. Available in maple, oak, or cherry, choose from traditional or carved pieces to add detail to cabinetry, furniture, or mirrors. Klise. 616.459.4283. www.klisemfg.com.
Clear Canopy
Stainless steel support brackets and UV-resistant acrylic panels comprise Lightline over-door canopies, offering a stylishly industrial look. Durable and weather-resistant, the canopies feature integrated rain gutters. Easy-to-assemble kits come in a variety of styles and sizes with clear or frosted-pane finish options. Feeney Architectural. 800.888.2418. www.feeneyarchitectural.com.
Stone Surround
Customers’ design ideas and design elements already in the home can be incorporated into Texas Carved Stone sculpted limestone fireplace mantels. Historic reproductions are also a company specialty. Original mantel designs were inspired by European antiques, though the company has branched into other designs and motifs, such as woodland scenes. Texas Carved Stone. 254.793.2384. www.texascarvedstone.com.
Lauren Hunter
