Adding to its extensive line of corner beads, Trim-Tex has introduced its Rigid Jumbo Corner Bead, featuring extra-wide 13/4-inch mud legs. The I-beam nose creates a sharp, distinctive outside corner allowing for easier mudding and crisp transitions. An exclusive T-arch punch helps installers achieve smooth, tight corners.
For basements, garages, and other areas where concrete walls are involved, try the new Caulk Channel Tear Away. The strip creates a ¼- by 3/16-inch reveal and can also be used to cover expansion areas filled with fire-rated or acoustical caulk. For use with ½-inch or ?-inch drywall. Trim-Tex | 800.847.2333 | trim-tex.com
