Liquid Nails. New Subfloor & Deck Construction Adhesive features a nonflammable, extreme-temperature formula that guns easily in temperatures as low as 22º F, and will not run or drip at temperatures up to 120º F, the maker says. Suitable for most common building materials, the adhesive is able to bond wet, frozen, and treated lumber, and can bridge gaps up to 3/8 inch. Subfloor & Deck Construction Adhesive is VOC-compliant nationwide and is available in 10- or 28-ounce cartridges. 800.634.0015. www.liquidnails.com.
