Lochinvar Recalls Boilers Due to Carbon Monoxide Poisoning Risk
The recalled boiler's flue grommet can deteriorate and dislodge during sue and allow the product to emit carbon monoxide.
Adobe Stock
Lochinvar has recalled around 34,300 condensing residential boilers due to the risk of carbon monoxide poisoning, according to an announcement from the Consumer Product Safety Commission (CPSC). The recall involves residential condensing boilers, combi boilers, and packaged systems sold after August 2016.
According to the CPSC, the boiler’s flue grommet can deteriorate and dislodge during use and allow the boiler to emit carbon monoxide, posing a risk of poisoning to homeowners. The manufacturer has received seven reports of a boiler’s flue grommets deteriorating, including one report of two nonfatal injuries involving carbon monoxide poisoning. Lochinvar has also received two reports of carbon monoxide emission that did not result in injuries.
The recalled boilers were sold under the Lochinvar, A. O. Smith, and State Proline brand names and have serial numbers within the range of 103475818 through 115078306, according to the CPSC. The model number and serial number are printed on the data plate located on each boiler’s rating plate. The brand name is printed on the front of each unit. The CPSC has provided a full list of recalled modeled numbers.
The boilers were sold by independent contractors, plumbers, and plumbing supply vendors and distributors between August 2016 and June 2020. The CPSC said consumers are advised to immediately contact their installer or a qualified technician to schedule a repair.
Vincent Salandro
