Masco Verve Living System Lighting Control
Masco. The wireless Verve Living lighting control system requires less wiring and has lower material and installation costs than other systems, the maker says. Verve light switches use energy-harvesting radio frequency technology, which turns the motion of flipping a switch on or off into the energy needed to transmit the radio signal. Wiring only needs to run from the utility panel to a central controller, and then to each light. 800.542.3789. www.vervelivingsystems.com.
Lauren Hunter
