Product Roundup – January 2020 Edition
New and noteworthy products
  • Innovative Shower Base
    The MTSB-6036SOHD shower base by MTI Baths is designed to conceal the position of an existing tub drain behind a wider top drain cover.
  • Re-engineered Subfloor Screws
    Simpson Strong-Tie Strong-Drive WSV Subfloor screws were re-engineered from head to point to reduce driving torque, and speed up installation.
    Fastening Systems - FastenersºFastening Systems - Quik Drive®
  • Liquid Roof Flashing Resin
    CertainTeed’s new SmartFlash One roof flashing resin is a one-component, UV-stable, fluid-applied solution for both steep- and low-slope-roof flashing details and repairs.
  • Wood Siding Clips
    Nova USA Wood Products QuickClips are made from marine-grade extruded aluminum, fastened with #10 pan-head screws, and work with almost all hardwood siding.
  • Capped Wood-Composite Decking
    MoistureShield’s new line of 5/4 capped wood-composite decking, called Elevate, is targeted to the entry-level market.
To find out more about the latest products and tools, click here.
