Product Roundup – March 2020 Edition
New and noteworthy products
  • Light Composite Decking
    The Infinity-I Series from Fortress Building Products uses a bamboo capped-composite formulation to provide strength, durability, and performance.
  • Smart Water Sensor
    The new Flo by Moen Smart Water Detector is a stand-alone sensor that can be placed anywhere in a home to alert users via push notification if it detects moisture, a change in temperature, or a change in humidity.
  • Code-Listed Post Bases
    Simpson Strong-Tie’s MPBZ line of column and post bases are available in 4×4, 6×6, and now 8×8 sizes. All three are code listed under ICC-ES ESR-3050 for uplift, download, and lateral resistance, as well as for allowable moment in reinforced concrete footings.
    ProductPhoto
  • Wind-Resistant Shingles
    GAF’s new Timberline HDZ shingles create a dual-phase, shingle-to-shingle seal when used with GAF’s DuraGrip sealant, as well as an asphalt-to-asphalt monolithic bond. In addition, the new StrikeZone nailing area is up to 600% larger than Timberline HD shingles.
  • Folding Glass Wall
    NanaWall Systems recently launched its SL84 aluminum framed system. With its slim frame profile intersection of just 3 7/8-inches, SL84’s four-fold and six-fold panels can reach a maximum height of 11'-6" and a maximum width of 3'-7".
To find out more about the latest products and tools, click here.
