Fine-grit sandpaper and a carpenter’s patience have nothing on the smooth finished surface of Woodgrain Millwork’s Finished Elegance interior trim and moldings. Technology from Eastman Cerfis helps achieve a finish that’s more durable and more water-resistant than sanded-and-painted trim, the maker says, even with multiple coats. Installed with Finished Elegance caulk, the trim requires no priming or painting. Woodgrain Millwork | 888.783.5485 | woodgrainmillwork.com
Waterproof Gypsum Backerboard
Expansive Glass Wall
Interior Fire-Rated Plywood
