A First Look at 2008 IBS Products
Bosch Tools.
The Hole Enlarger Kit fixes holes that are cut too small or widens old holes that won’t fit larger materials. Users enlarge holes by attaching a hole saw, which matches the desired hole size, to an enlarger nut, then attaching a cup matching the original hole size. The inner cup acts as a pilot guide, allowing the outer cup to cut a clean hole. Two thread profiles accommodate cup sizes from 9/16 inches to 6 inches. Kits work with Bosch’s bi-metal hole saw cups and most major brand hole saws. 877.267.2499. www.boschtools.com.
Crossville.
Add a punch of color or a subtle accent with Glass Blox tiles in a palette of 44 colors. All solid colors come in 1-inch square mosaics, 2-inch-by-4-inch rectangles, linear bars, and 4-inch square tile. Blends are available as mosaics and liners. A percentage of the profits from these products is donated to the Common Thread for the Cure, a foundation that supports families in the furnishings industry who are battling breast cancer. 800.221.9093. www.crossvilleinc.com.
Clopay Building Products. Gallery Collection garage doors feature a layer of chlorofluorocarbon-free polystyrene insulation pressure bonded between two sheets of 24-gauge steel. The designs offer both long- and short-grooved panels that can combine with insulated square, rectangular, or arched windows. Decorative handles and window options are available for the doors, which measure 6 feet to 12 feet high and up to 20 feet wide. They come in four colors and can be painted. 800.225.6729. www.clopaydoor.com.
Jeld-Wen.
A one-touch automatic lock now comes standard on all of the maker’s premium vinyl slider and single-hung windows. MAG-Lock allows homeowners to use one finger or the side of a hand to operate and lock the windows. Integrated into a fully concealed mechanism that is streamlined into the window profile, the magnets will maintain their force after 36,000 cycles, the company says. 800.877.9482. www.jeld-wen.com.
Nuheat.
Compatible with the maker’s electric floor-warming mats, the Nuheat Cable System lets users extend radiant floor heating into intricate — even wet — spaces, including shower stalls, benches, saunas, and platforms. The 3/16-inch-thick components make for a minimal increase in floor height, and can be installed under tile, stone, marble, laminate, or engineered-wood floors. The system is energy-efficient, generating just 12 watts per square foot, and can be controlled using the maker’s programmable thermostats. 800.778.9276. www.nuheat.com.
Pass & Seymour/ Legrand. Responding to revisions in the National Electrical Code regarding child safety, the maker introduces a new line of tamper-resistant receptacles featuring a patented, UL-listed shutter system to protect children from injury. Offerings in the line include tamper-resistant hallway light/receptacle combination devices and decorator receptacles, and a tamper-resistant GFCI (shown). Several other products are also available. Shutters on the receptacles will not impair normal plug insertion, removal, or function. 800.611.7277. www.passandseymour.com.
Kohler. Requiring just 1 gallon per flush, the one-piece San Raphael toilet could save a household of four between 7,000 and 10,000 gallons of water annually, compared with a 1.6-gpf model, the maker says. To maintain robust flushing power, the toilet uses compressed air within the reservoir to propel water to the rim and siphon jet. Comfort Height seating and an elongated bowl offer ease-of-use. 800.456.4537. www.kohler.com.
L.E. Johnson Products. When a sliding pocket door is not an option, 2610F wall-mount door hardware can offer some assistance. The hardware is surface mounted outside the wall and is ideal for those applications where a swinging door isn’t feasible. No close fitting is required, and the hardware can be adapted for particular installations. The hardware can support doors weighing up to 125 pounds. 800.837.5664. www.johnsonhardware.com.
