Simonton.
Add space and light to kitchens, baths, home offices, and elsewhere with a garden window. Available as a one-piece unit for easy installation, the garden window includes an adjustable tempered glass shelf and a 1¼-inch birch veneer seatboard. Other features include operable sidelites, a fusion-welded frame and sash, and a snap-in sill cover to resist water penetration. Options include an Energy Star glass package, colonial flat grids on the glass, an additional glass shelf, and oak veneer or white Pionite laminate seatboards.
800.746.6686.
www.simonton.com.
RLC Technologies.
Eliminate the need to cut and bend tabs or to miter corners when installing J-channel. With the Kwik Corner for J channel, users simply measure the height and width of the window or door, cut the J-channel to those measurements minus 1/8 inch, and insert it into the corner piece. The finished frame is easily nailed in place around the window or door for a finished look.
866.781.5945.
www.kwikcorner.com.
YKK AP.
New to the residential market, the maker introduces StyleGuard impact-resistant and StyleView standard vinyl windows. A wide range of configurations includes twin casement, casement picture, and awning windows. Low-E glass and low-conductivity spacers optimize thermal efficiency, while double weather stripping and a multi-point lock help protect against the elements and lower utility bills.
678.838.6093.
www.ykkap.com.
Marvin.
The Ultimate Replacement Casement window has the best of both worlds, the maker says, with features that benefit installers and homeowners. Easily installed as a frame-in-frame insert, the window slips into virtually any existing window space without the need to disturb siding, wallpaper, or millwork. An exclusive wash mode is accessible by popping the window's hardware out of its channel, allowing the window to rotate inward. Standard features include Low-E II with argon insulating glass, extruded-aluminum–clad exterior, and satin taupe hardware.
888.537.7828.
www.marvin.com
