All Decked Out: 8 New Products from the Deck Expo Show Floor
The ever-expanding alternative decking category has numerous new additions.
With the decking industry continuing to grow, the floor of the 2014 DeckExpo was busy and filled with new products for outdoor living. New brands, as well as new products from well-known brands were easy to spot throughout the show floor. The alternative decking category continues to expand, while under-deck drainage and deck accessories like lighting are getting renewed focus. Below are eight new products our editors found on the show floor. Add those to this list of 10 more new products that debuted at Deck Expo.
Admiral SpaceMaker Outdoor Flooring
Admiral SpaceMaker’s “Super Seal” interlocking design and specialized edge components direct water to the edges of the boards and away from foundation walls, keeping the space underneath clean and dry. Unlike aftermarket or secondary products used to create underdeck drainage, Admiral SpaceMaker PVC materials let installers create usable space below decks with a single product and installation. Admiral Spacesaver | admiral-spacemaker.com
Deceuninck Baluster and Deck Lighting Options
New deck lighting and baluster options are available to complement the maker’s Clubhouse Decking product line. Clubhouse Lighting comes in black, white, and contrasting bronze, and includes post cap lights, down lights for deck posts, and step lights, as well as recessed deck lights for use on stairs, walkways, or perimeters. Deckorator balusters are also available to help accent outdoor living spaces and are custom-coated to match Clubhouse Elite Railings. Choose from round, square, or 4-inch glass slats. Deceuninck USA | clubhousedecking.com
Dexerdry Deck Waterproofing
Adding a rubber mallet to your toolbox is all you need to install Dexerdry as part of your next deck project. The above floor joist flange act as spacers for deck boards while waterproofing the deck and providing dry, useable space underneath. Designed to withstand the element, Dexerdry is low-maintenance and can withstand 3000 psi powerwashing. Dexerdry | 732.551.9969 | dexerdry.com
MoistureShield Brazilian Chestnut Colorway
A third color has been added to the MoistureShield Pro collection. Brazilian chestnut features a wide color variation ranging from light to deep browns, replicating its namesake hardwood. Other colors in the line incldue graystone and ipe. MoistureShield Pro combines a composite core with an extra-thin capstock to provide fade, stain, scratch, and slip resistance. The boards can be installed on-ground or even underwater without voiding the product warranty. MoistureShield | moistureshield.com
NyloBoard NyloPorch Porch Flooring
NyloPorch is the latest introduction from NyloBoard, and is made from the same composite material as the original decking material – 100% recycled carpet fiber. The tongue-and-groove porch boards contain no wood or PVC, and resist moisture, mold, mildew, and termites. Available in 3- and 5-inch widths and the same five colors as NyloDeck, NyloPorch is rated for uniform live load of 100 pounds per square foot with support framing spaced at up to 24 inches. The material is backed by a 25-year fade and stain warranty, and a 25-year limited residential warranty. NyloBoard | 877.695.6909 | nyloboard.com
Palram Paldeck PVC Decking
Entering the PVC decking market, Paldeck is produced using “cool” color technology to reduce heat building in the boards. This resistance to damage from high temperatures, extreme climatic conditions, and corrosive environments makes Paldeck a durable option backed by a 25-year warranty. Palram | palram.com
Royal Building Products Zuri Premium Decking
This alternative decking option combines the durability of PVC with photorealistic imaging to create a true exotic hardwood look in a low-maintenance product. A clear acrylic overlayer seals around the edges of the printed photo, securing it to the board and protecting it from the elements. The acrylic provides a finish that resists scratches, stains, fading, and moisture. With minimal grain pattern repetition, homeowners will be pleased with the natural aesthetic. Royal Building Products | zuri.royalbuildingproducts.com
ZomeTek Bamboo Decking
Drawing on its experience in bamboo materials, Aboeda introduces Zometek composite bamboo decking. A blend of natural bamboo fiber and recycled HDPE plastics creates a durable, construction-grade material. The low-maintenance decking is available in five through-color options, and users can choose from reversible deck boards with smooth and grooved textures on opposite sides, or 12-inch square decking tiles in mosaic or slat patterns. ZomeTek | 800.607.2414 | zometek.com
Lauren Hunter
