Bosch’s FlexClick System
The new GSR12V-140FC multi-use drill/driver system includes four interchangeable heads.
Bosch Power Tools
The GSR12V-140FC FlexClick system is a compact “pocket” drill/driver similar to the PS22 that Doug Mahoney reviewed for us a few years ago. Unlike the PS22, the Flexiclick runs off of a brushed motor that’s powered by a 12V max compact battery (which runs many other tools, like the cordless JS120BN Jigsaw). Both drill/drivers have a no-load RPM of 0-400 (Low or speed 1) and 0-1,300 (High or speed 2). The GSR12V-140FC is also incredibly compact, weighing 1.8 lb (with battery). That’s where the similarities end, and the GSR12V-140FC takes off on the fast track.
The GSR12V-140FC kit comes with 4 attachments, each with its own unique skillset. Each of the attachments can be added or removed with a simple 1/4 –turn and “click”. The drill/drive itself, without the attachments, can accept a ¼” hex bit. This main hex drive is magnetized so bits won’t fall out. Attachments include: a 3/8” keyless chuck, a ¼” hex locking bit holder, a ¼” offset locking bit holder and a right-angle attachment for using the keyless chuck, hex bit holder, or offset bit holder. Both the offset bit holder and right angle attachment can be rotated to 16 positions without removing them from the drill.
The drill/driver has 21 clutch settings (including typical “drilling” mode), as well as an LED, which turns on with the trigger (you can turn the LED on by lightly pressing the trigger and not engaging the driver, which is nice). It features onboard battery fuel gauge, as well – which, too, can be engaged without pressing the trigger completely to start the drill.
The GSR12V-140FC kit costs $199 and includes:
  • 12V Max Drill/Driver
  • Keyless 3/8” Chuck Attachment
  • ¼” Locking Bit Holder Attachment
  • Right Angle Attachment
  • ¼” Offset Angle Attachment
  • (2) 12V Max Lithium-ion Batteries
  • 12V Max Fast Charger
  • Carrying Bag
This article originally appeared in Tools of the Trade.
Chris Ermides
