Choosing a Power Planer
For a general purpose tool, look for power and light weight
23 MIN READ
Choosing a Power Planer, continued
PLANER PROFILES
Bosch 3296K
This is an accurate, well-made machine. The front shoe rides up and down on sloped ways, and the depth-of-cut settings are especially easy to gauge. The 3296K comes with one of the nicest adjustable fences I’ve ever used. Chips can be ejected from either side of the planer, though the mechanism for changing sides was sticky on the particular tool I tested. This tool is powerful enough to make a 3/32-inch cut, but the exhaust chute tends to clog when you do it. The 3296K is comfortable for right-hand use, but the trigger safety makes it awkward for left-hand use.
Bosch 3365
This planer is small, light, and very maneuverable. Chips can be ejected from either side of the tool. The 3365 runs at a slightly higher rpm than other planers and uses a single blade. According to the manufacturer, this cuts your blade costs because when you hit a nail, you only ruin half a set. This tool runs so smoothly that I couldn’t tell from use that it has only one blade. This model has a 10-foot cord and comes with a simple 90-degree fence. Chips can be ejected from either side, but the chute will clog if you cut too quickly. The blades are held in place by a single pair of set screws, so changes are quick and nearly idiot-proof.
Craftsman 27716
This retro-looking tool has indexed depth settings and easy-to-change bolt-on carbide blades. Chips are ejected to the right through an adjustable nozzle that can be aimed away from the user. This Craftsman planer comes with a single-piece 5-degree door beveling fence that screws to the side of the housing. The fence may not look like much, but it does the job. Unfortunately, this tool is under-powered for its size. The motor labored and the exhaust chute frequently clogged during full-depth cuts on 1 1/2-inch-wide joists.
DeWalt DW678K
The DW678K is big and powerful, though somewhat heavy. With a cutting capacity of 5/32-inch, it’s tied with Festo for maximum listed depth of cut. However, this tool tends to clog during full-depth cuts, even on 1 1/2-inch stock. On the plus side, a removable sleeve in the chip chute makes it safer and easier to clear blockages. And the sleeve is reversible, so chips can be ejected from either side of the machine. This tool has a very comfortable grip, but if you’re a left-hander, you need to be careful not to accidentally engage the trigger lock with the palm of your hand. I like the indexed depth settings and the way the parking foot locks up out of the way for cuts that start in the middle of a board.
DeWalt DW680K
The DW680K doesn’t have every feature you can get on a power planer, but the ones it has work just fine. It’s light and easy to handle, and the motor shows no strain during full-depth (1/16-inch) cuts. Although the chip chute only ejects to the right, it rarely gets clogged. This tool has a long cord, indexed depth-of-cut settings, and a parking foot that can be locked out of the way. It comes with a simple 90-degree fence and a sturdy metal case. The only thing I don’t like about this tool is the trigger lock, because it’s located in such a way that a left-hander could accidentally activate it.
Festo HL850E
If power planers were cars, Festo’s would be a Rolls-Royce. It uses a single disposable spiral-cutting carbide blade. The head is removable and can be swapped out for optional heads that produce a variety of textured surface finishes. For example, I tried one that uses a convex blade to plane adze-like cuts in the surface of beams — something a timber-framer might like. The blade comes flush to the right side of the motor housing, so there’s no limit to the depth of rabbet cuts. This means that the HL850E can plane all the way into an inside corner, like the joint between the baseboard and flooring. This tool is exceptionally quiet because it runs at a constant speed of 10,000 rpm. The standard dust bag actually works, and you can get an optional angle fence. This is easily the most versatile planer I tested, but at a cost of over $400, it’s more planer than most carpenters can afford.
Freud FE82
The FE82 is a well-made tool with simple solid features. Cuts come out straight because the front and rear shoes remain parallel at all depth settings. It comes with a rigid 90-degree fence and a vacuum adapter. Blades are easy to change, but I didn’t like the short cord or the way the parking foot gets in the way when you start cuts in the middle of the board. Except for the low price, there’s nothing very special about this tool.
Hitachi P20SB
This tool is light, simple, and inexpensive. In terms of usage, it’s a good general-purpose planer. But in terms of features, it’s a throwback to the sort of planer I was using 15 years ago. It doesn’t matter that the tool doesn’t have a parking foot, and it’s not a deal breaker that the chips only eject to the right. But the P20SB doesn’t use the disposable carbide mini-blades that are now standard on nearly every planer; instead, you have to use a clunky knife-setting jig, so changing blades is more of a hassle than it should be.
Hitachi P20DA
This is a very interesting new tool, a 12-volt cordless planer. The P20DA is about the same size and weight as Hitachi’s corded model, though the location of the battery makes it noticeably tail-heavy. As you would expect, it’s significantly less powerful than a corded tool, which is why the maximum depth of cut is only 1/64 inch. The tool does a good job making light finish cuts, but isn’t up to planing framing stock. The manufacturer claims that it will plane 100 feet of 1 3/4-inch stock on a single charge. That seems about right: I tested it on the edge of a 2×12, and it cut 112 feet before the battery gave out. Unlike Hitachi’s corded model, this one uses disposable carbide mini-blades.
Makita N1900B
This tool is nearly indistinguishable from the planers Makita was making 15 years ago. It’s a simple, straightforward machine without a lot of bells and whistles. Like its predecessors, the N1900B clears chips well and comes with a short 90-degree fence. Unlike the original model, this one takes standard carbide mini-blades. It’s reasonably powerful for a 5 1/2-pound tool, but in its factory configuration it is limited to a 1/32-inch cut.
Makita 1050DWA
This planer proves how deceiving looks can be. When I opened the box, I thought it was a toy, but once I started using it, I was impressed by how well it worked. I was especially impressed by the amount of work it can do on a single charge. According to the manufacturer, it can plane 140 feet on a single charge, but I managed to get 232 feet planing the edge of a 2×12. The 1050DWA is smaller and lighter than Hitachi’s cordless model but is limited to making 2-inch-wide cuts. The narrow cutting width is a reasonable compromise, given that no cordless planer is really up to making 3 1/4-inch cuts. I wouldn’t use the 1050DWA to straighten framing, but I could see buying one to scribe cabinets or plane the occasional door. At $290, it’s definitely a luxury item, one that’s easier to justify if you’re already using Makita’s 12-volt system.
Metabo 0882
This tool exhibits the same European sensibility that Festo’s and Bosch’s planers do. It has precise indexed depth settings and a front shoe that’s always parallel to the rear shoe. The chip chute ejects from either side and can be switched by flipping a baffle. The spring-loaded parking foot is better than most in that it’s heavy enough to stand up to abuse but doesn’t get in the way because it retracts when you push down on it. This tool has plenty of power, even at the full 1/8-inch depth of cut. The 0882 has an exceptionally long cord and comes with a 90-degree fence. My only complaint about this planer is that it doesn’t come with a case.
Porter-Cable 125
The best thing about this tool is that it’s powerful and capable of making nice deep cuts. It’s also a plus that it comes with an adjustable bevel fence. The shoes on the planer I tested, however, went out of parallel at maximum depth of cut. As a result, deep cuts tended to be bowed cuts. You have to rotate the control knob multiple times to move between minimum and maximum depth settings, and the numbers on the depth scale overlap, so it’s easy to lose track of exactly where you are. This tool is light and well balanced, but a safety makes it awkward for left-hand use. Exhaust is to the right side only. It’s a minor point, but the fence fit so tightly in the molded plastic case that I had to pry it out with a screwdriver.
Porter-Cable 126 (Porta-Plane)
After having been around for years, the Porta-Plane was discontinued a couple of years ago. However, there was such an outcry that the manufacturer brought it back as the model 126. Unlike most of the planers I tested, this tool is designed to plane long narrow pieces of stock — in particular, the edges of doors. It has a 16-inch base and a long, nonremovable fence that tilts from minus 15 degrees to plus 45 degrees. An adjustable stop allows you to preserve preset angle settings. The front shoe moves smoothly up and down by moving a lever on the front of the housing. The base is only 2 1/4 inches wide, but that’s plenty for most doors. The Porta-Plane takes a spiral-cutting head that is easily removed for sharpening. Except for the cap on the end of the motor housing, this is an all-metal machine.
Virutex CE96H
When I was in boat-building school, I once joked that someday I’d throw away my old-fashioned compass plane and replace it with a power-driven model. That got a good laugh, because at the time there was no such thing as a power compass plane. But several years ago, Virutex introduced the model CE96H. It’s just like any other power planer except that the base is made from a thin, flexible sheet of metal. As a result, the base can be adjusted to follow inside and outside curves. The minimum concave radius it can do is 17 3/4 inches; the maximum convex radius is 15 3/4 inches. Although it’s power driven, it still takes finesse to use this tool. That said, if you’re one of those rare carpenters who planes a lot of curves, this might be the planer of your dreams.
PLANER SPECS
Manufacturer
Model
Street Price
Weight (lbs.)
Cord Length
Motor Rating
Max. Depth of Cut
Width of Cut
Length (front to back along the base)
Bosch
3296K
$179
6.4
6′ 8″
6.5 amps
3/32″
3 1/4″
11 1/2″
Bosch
3365
$109
10′
5.0 amps
1/16″
3 1/4″
9 7/8″
Craftsman
27716
$139
7.8
10′
5.5 amps
1/16″
3 5/8″
10 3/4″
DeWalt
DW678K
$249
9.2
9′ 4″
7.8 amps
5/32″
3 1/4″
12 1/2″
DeWalt
DW680K
$161
5.5
9′ 4″
5.2 amps
1/16″
3 1/4″
11 3/8″
Festo
HL850E
$436
8.6
12′ 8″
7 amps
5/32″
3 1/4″
13 5/8″
Freud
FE82
$109
6.5
7′ 6″
6.2 amps
3/32″
3 1/4″
11 1/4″
Hitachi
P20SB
$114
6.1
8′
3.4 amps
1/32″
3 1/4″
11 5/8″
Hitachi
P20DA
around $250
6.4
n/a
cordless 12-volt
1/64″
3 1/4″
11 5/8″
Makita
N1900B
$139
5.5
8′ 9″
4.0 amps
1/32″
3 1/4″
11 1/2″
Makita
1050DWA
$290
4.6
n/a
cordless 12-volt
1/64″
2″
9″
Metabo
0882
$225
14′
6.5 amps
1/8″
3 1/4″
11 1/2″
Porter-Cable
125
$149
5.5
9′
6 amps
1/8″
31/4″
11 1/4″
Porter-Cable
126
$399
10′
7 amps
3/32″
2 1/4″
16″
Virutex
CE96H
$325
7′ 8″
6.7 amps
1/8″
3 3/16″
9 1/2″
Manufacturer
Model
Max. Rabbet Depth
RPM
Blade Type
Standard Accessories
Place of Manufacture
Bosch
3296K
15/16″
13,000
standard inserts
steel case, angle fence, rabbeting depth stop
Switzerland
Bosch
3365
5/16″
18,000
standard inserts
90-degree fence, vacuum adapter
Switzerland
Craftsman
27716
3/16″
16,000
Craftsman-brand blades
USA
DeWalt
DW678K
1″
12,000
standard inserts
metal case, rabbeting depth stop, 90-degree fence
England
DeWalt
DW680K
1/2″
15,000
standard inserts
metal case, 90-degree fence
England
Festo
HL850E
unlimited
10,000
Festo spiral inserts
plastic case, dust bag, rabbet depth stop, and 90-degree angle fence
Germany
Freud
FE82
1/8″
14,000
standard inserts
case, dust collection nozzle, 90-degree fence, rabbeting depth stop
Spain
Hitachi
P20SB
15/64″
15,000
Hitachi-brand blades
case, straight guide, blade-setting gauge
China
Hitachi
P20DA
15/64″
13,000
standard inserts
battery, charger, plastic case, 90-degree fence, 2-amp hour battery
Japan
Makita
N1900B
11/32″
15,000
standard inserts
USA
Makita
1050DWA
9/16″
9,000
Makita inserts
plastic case, 90-degree fence, battery, charger, dust bag, 2-amp hour battery
Japan
Metabo
0882
7/8″
12,000
standard inserts
rabbet depth stop, 90-degree fence, dust collection nozzle
Germany
Porter-Cable
125
7/8″
14,000
standard inserts
plastic case, bevel fence, rabbeting guide
Italy
Porter-Cable
126
n/a
23,000
removable spiral head
metal case, permanent fence ­15 degrees to +45 degrees
USA
Virutex
CE96H
n/a
16,500
standard inserts
fence
Spain
PLANER MANUFACTURERS
Bosch S-B Power Tool
Chicago, IL
877/267-2499
www.boschtools.com
Craftsman Sears Power Tools
Garland, TX
800/377-7414
www.sears.com/craftsman
DeWalt Industrial Tool
Hampstead, MD
800/433-9258
www.dewalt.com
Hitachi Power Tools
Norcross, GA
800/546-1666
www.hitachi.com/powertools
Festo ToolGuide
Santa Barbara, CA
888/463-3786
www.toolguide.net
Freud U.S.A.
High Point, NC
800/472-7307
www.freudtools.com
Makita U.S.A.
La Mirada, CA
800/462-5482
www.makitatools.com
Metabo
West Chester, PA
800/638-2264
www.metabousa.com
Porter-Cable
Jackson, TN
800/321-9443
www.porter-cable.com
Virutex
New York, NY
212/989-9868
www.virutex.com
David Frane
